Old 12-16-2003, 05:52 PM
jbrad jbrad is offline
A.M. Stations won't come in.
The A.M. Stations on my stock radio (1996 Taurus) won't come in. The F.M. works fine. Any ideas what might be wrong?
Old 12-16-2003, 08:00 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: A.M. Stations won't come in.
Does AM come in on other people's radios in the area you are at?
Old 12-16-2003, 10:14 PM
Re: Re: A.M. Stations won't come in.
YES.
Old 12-16-2003, 10:43 PM
Haibane's Avatar
Is it it doesn't come in, or it comes in with a lot of buzz. Some radios have worse reception than others.
Old 12-17-2003, 06:40 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
after thinking about this for a while ........ the only thing I can come up with is - check the antenna and make sure it is grounded good, check both sides of the cable (at the radio and the car). Another option is, it may be set to european frequencies - US ones are 10 KHz apart, european ones are 7 or 9 KHz apart, I can't remember. Copmare your tuners freqs with a buddies.
Old 12-28-2003, 05:23 PM
Ground Rat's Avatar
Ground Rat Ground Rat is offline
Send a message via AIM to Ground Rat
Your radio is possibly bad. The AM and FM are actually two different radios. Guess it's time to upgrade. Or you could crack it open and see if there is a simple part to replace.
'87 Turbo Sprint
'90 Turbo Voyager
'92 Typhoon #591
Old 01-01-2004, 08:36 PM
mtdxx mtdxx is offline
I had the same problem, it sucked, i feel for you man! I never resolved the problem. The car was a peice. I got rid of it when the area where the door hinges attached rusted out and the door fell off.
I love those talk stations on AM.
03 Cd jammed in cd player, won't come out. 93 silo Silhouette 1 12-26-2006 11:09 AM
1996 Taurus Car Streo A.M. signals won't come in jbrad Taurus | Taurus Wagon 0 12-16-2003 05:49 PM
