Go Back   Automotive Forums Car Chat > Buick > Regal
Old 12-16-2003, 02:03 PM
rknopp rknopp is offline
98 Regal stall when Turn signal activated
What would cause a 1998 Buick Regal to stall when the Turn Signal is activated?
Old 12-16-2003, 09:38 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Re: 98 Regal stall when Turn signal activated
Your ignition switch!!! I repaet your ignition switch replace it and you will be fine!
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 02-13-2004, 01:44 PM
bramleybc bramleybc is offline
1998 Buick regal ignition swithc
Did replacing the switch fix the problem? Was it switch or cylinder?
Have the same problem as you but is intermittent.
Old 02-13-2004, 06:51 PM
Flatrater's Avatar
Main GM Guy
I have done at least 10 os these switches in the past year for this problem. It does fix it trust me.
If you want go to your fuse box find the ignition fuse with a meter across the fuse while the problem is occuring you will see less than 12 volts.
ASE Master Tech
ASE Advanced L1
GM Master tech
Old 02-13-2004, 08:30 PM
comp comp is offline
He knows what he's talking about guy's
Old 02-13-2004, 10:42 PM
Wink Re: 98 Regal stall when Turn signal activated
Thanks for the response. I had heard that there was also a problem with the ignition cylinder. You are specifiying the switch so will have it replaced. Thanks again
Switch replaced problem solved thanks!!!
Old 04-29-2004, 08:20 PM
omegaman76 omegaman76 is offline
Re: flatrater please help
i have a 1998 buick regal. the car won't start, engine won,t turn over and all dash lights on, when turn signal moved fuel pump energizes. believe the security system is cutting the ignition. is the problem the ignition switch, or the ignition lock cylinder, or is it the same part?
Car stalling when turning and braking (Holden VX Commodore Lumina) Asmodaes Commodore/VS/VT/VX 4 11-19-2010 11:00 PM
car stalls when turning left persondude44 Engineering/ Technical 5 04-16-2009 08:18 AM
Buick Regal stalls when turn signal on and stopping cabishop Regal 4 12-01-2008 08:35 PM
Buick Regal 1998 stalls when turn signal on and stopping. autoreagaltom Regal 1 03-22-2008 08:12 PM
Buzzing noise when turn signal is activated Zom Explorer | Explorer Sport Trac 5 04-26-2005 03:33 PM
