Re: Buick Regal 1998 stalls when turn signal on and stopping.
Hello, It appears that I have the identical problem. I would appreciate obtaining more details on the fix that you found successful i.e. ignition switch (the entire ignition or just electonic portion); and the harness (any particular part ... how would I describe it to the mechanic?) When I had my car on the diagnostic test equipment the computer and harness checked out. I am wondering if the ignition replacement would do the trick). I was also trying to track down the rational which you mentioned was on the forum. I do not know how to do it since I am a beginner. I am also not a mechanic so I want to have my facts straight when I tell mechanic something different than he suggests. He suggests replacing the turn signal and maybe computer .... to see if problem is solved.
Look forward to some words of wisdom, thanks ... |
Re: Buick Regal stalls when turn signal on and stopping
Welcome to AF.
Your post has been moved to its own thread. We prefer that old threads are not resurrected. Just do a forum search using keywords "ignition switch". Lots of posts on the issue including what the part looks like and the replacement procedure. Computer? Don't let him rip you off.
Cheers Stripe |
Stripe,
Are you addressing your reply to me or the OP? If you quote me in your reply then you are addressing me. You might consider adjusting your posting etiquette. http://www.automotiveforums.com/vbul...24&postcount=3 Quote:
Sorry BNaylor I did try to edit right after I hit the send button but I could get it to work. I will triple check in the future before posting Chers Stripe |
