Old 12-16-2003, 09:09 AM
DarkAccord600 DarkAccord600 is offline
Send a message via AIM to DarkAccord600
Brake Booster
I plan on doing a rear drum to disk conversion on my Accord. I need to know if the brake booster for my rear drum accord can be used when I switch over to disk.
Old 12-16-2003, 12:38 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: Brake Booster
Depends on if you swap out master cylinders. If not then you don't need too. If you do switch to a bigger one, then you may need to, to move the fluid through the MC.
Old 12-18-2003, 11:18 PM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
Re: Brake Booster
do you know if your accord's brake system use combination valve, metering valve, porportion valve or none at all?
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
Old 12-20-2003, 11:58 PM
Re: Re: Brake Booster
Explain?
Old 12-21-2003, 07:17 AM
Re: Brake Booster
What he is saying is, which of these systems does your Accord employ? But since they are built into what is called the proportioning valve it's irrelevent.
Old 12-23-2003, 03:47 AM
Tofuboy's Avatar
Actually it is being build into what is called "combination valve" not propertioning valve, which includes metering valve, proportioning valve and pressure differential switch for most cars of today.
I don't know if your year and model accord offers "option" for 4 wheel disc brake or has an aftermarket kit to switch over, but if you think you can just slap on a disc and caliper for the rear and have better braking then you are totally wrong.
In the event of converting a rear drum to disc, you will most likely need a new combination valve that has been calibrated to prevent rear wheel lock up and even braking so whenever you step on the brake your car will not "fish tail" (you may think this is fun, wait til you're trying to brake on the free way during high speed).
Anyway, your question is regarding the brake booster and the answer is most likely not. The brake booster is not the real answer to your project.
95 Civic EX
83 Toyota Starlet
Old 12-23-2003, 05:39 AM
Re: Brake Booster
He has a 96, and it's called a dual proportionoing valve, at least according to the Honda service manual. The metering valve and prop valve are built into what is called the proportioning valve. Technicaly it is a combination, as it contains both parts, but it isn't called a combination valve.
Old 12-23-2003, 06:55 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
JCRX is correct as to the name Honda has given the part...it may well be a combination valve of sorts in design, but the Part's name by Honda is a propertioning valve. That beng said, if he has a 96, is he swapping on the disc brakes from an EX? If that's the case, can't he use the EX master cylinder and propertioning valve. That should give him the correct brake balence, since it was designed for the 4 wheel disc system, which he is switching to.
Old 12-23-2003, 08:52 AM
I do plan on using all Ex parts to switch over but all I really needed to know was what parts to get.
Old 12-23-2003, 10:13 AM
Re: Brake Booster
Going from drum to disc in the rear you need, brakelines, and cables, maybe the complete trailing arms, I know the civics are the same, but the Accords may differ. Booster and master cylinder are optional if you're just doing the rears and not upgrading the fronts too. Your pedal will feel softer if you don't, but stop decent. The prop vavle is what you need to worry about, as Tofu said the rear brakes displace different amounts of fluid and it needs to be metered out correctly.
Old 12-23-2003, 10:42 PM
Do you know the exact proportion each wheel gets in the Ex.?
97 Chevy Blazer/Brake Booster ezh10111 Problem Diagnosis 4 12-22-2012 07:46 PM
99 T&C Power Brake Booster Squeal? SlimJimRD Caravan | Voyager 1 06-29-2009 09:28 PM
Brake Booster replacement causes brake lights to stay on, and brake power is VERY low Ultranpthing Let's get Technical! 8 09-22-2005 05:15 PM
Brake Fluid in Power Brake Booster Tom Thompson El Camino 2 03-24-2004 07:32 PM
