Old 12-16-2003, 04:27 AM
SenseiAccord SenseiAccord is offline
Best brake rotor design?
Does anyone know what is the best brake rotor design over all?
This is what i kno...
Slotter rotors (One with the lines) have more surface contact than any other rotor designed for better braking. It also runs cooler than stock rotors and helps prevent brake fade.
Drilled rotors (one with the holes) have a good cooling design and helps prevent brake fade. Prone to cracking since drilling creates stress points in the rotor. It has a less surface contact than slotted rotors
Drilled and slotted (one with holes and lines) have both designs in one but have a lot less surface contact than both of them too. It looks like it would run cooler since it looks like it has a lot of places where heat and gases can evacuate. Since it is also drilled then that means it can be prone to cracking too.
To me i think that slotted rotors are the best for stopping power and the drilled and slotted rotor has a great deal in cooling. Since the cooler it runs, the longer the brake pads will last and so on but the more surface contact u get the better stopping power u will get. Which one should i get or would u guys recommend. Right now i am thinking slotted rotors but i want to see everyones input on this. THANX!
Old 12-16-2003, 10:05 AM
pheurton-skeurto pheurton-skeurto is offline
Re: Best brake rotor design?
what you failed to mention on all of these is that they wear pads really fast. the cross drilled holes/slotted areas will actually shave part of your pad off with every rotation. i am kinda old school when it comes to brakes but i just stick to the smooth rotors. i normally end up going into napa (i know not the best parts store but i can put it on my familys account so parts are free) and get their top of the line upgraded pads/rotors. ive talked to plenty of guys with cross drilled/slotted rotors who have said that the $100 + that they spent on the rotors just wasnt worth it...you decide though, they do look cooler and give the perception of better braking...
1997 Honda Prelude Base
18G Turbo - 8 Psi
GReddy EVO Catback
1995 Honda Civic LX
Bone Friggin' Stock
Old 12-16-2003, 10:58 AM
93civic$racer 93civic$racer is offline
how much would someone spend on a big brake upgrade????
Old 12-16-2003, 01:48 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Re: Re: Best brake rotor design?
Even better than all of those is the kind I have, Powerstop rotors. They're slotted and dimpled. The dimples act like crossdrilled, but don't forfeit reliability. www.Inlinefour.com has them for $120 or so for a pair.
Old 12-16-2003, 02:12 PM
Doubletap Doubletap is offline
Send a message via AIM to Doubletap Send a message via Yahoo to Doubletap
The weakness of cross drilling is not going to be an issue unless you are autocrossing or road racing. Also they would be pointless otherwise becuase you will not need that much cooling power. You should do a search in the Wheels/Tires/Suspension forum. There were a few topics pertaining to this brought up recently. They will help you out I think.
DoubleTap
Old 12-16-2003, 04:12 PM
Ricochet's Avatar
Banned
Here's what I have
Old 12-17-2003, 04:08 AM
Whoa big brakes upgrade is hella expensive. Those are like 600+. Dont think they are really worth it unless you are going to be going like 200MPH and trying to stop to let a grandma cross the road. Nah but u never kno when u might need that kind of stopping power but i dont think it is worth it. ESP down here in hawaii where there is like no possible road to be doing 150 consistently. But if you can supply the money like nothing then like $700 is what i would spend on at the most. Also money down here is hard to earn and keep since we have such high home costs and stuff down here.
Old 12-17-2003, 09:43 AM
Ricochet's Avatar
Banned
Just get some EBC Greenstuff pads, rotors, and braided lines. pads - $80, rotors - $120, lines - $100. That will stop your car more than just fine at half the cost of a big brake kit.
Old 12-17-2003, 11:11 AM
xsimpleaznx's Avatar
xsimpleaznx xsimpleaznx is offline
i hear good things about brembo blanks, they are also the cheapest option at about $30 a rotor. cross drilled / slotted stuff will run you a little more and will have mostly aesthetic gains
Old 12-17-2003, 08:18 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
The best rotor design by far is the 2-piece "floating" type that more professional race cars use. Blank type disc pieces are best out of the 3 types, and then slotted are very closely behind. But a 2-piece rotor can dissipate heat MUCH better than your traditional OE style 1-piece rotor design. 2-piece is where the rotor hat is aluminum and sperate from the actual disc braking surface, and is thus bolted and safety wire tied to eachother.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 12-17-2003, 11:33 PM
BullShifter's Avatar
It all depends on what the car is used for.
Cross-drilled are only needed if your rotors glow RED HOT during heavy/repeated braking, no way your gonna do that on the street unless you leave the ebrake on or sticking caliper. If that were to happen, one doesn't belong on the road They do look the best
In most cases the type of pad matters more than the rotor surface, unless its a race car. Brembo blanks & performance pads do very well, for better looks you may want dimpled and/or slotted.
Braided brake lines will also do more than a cross drilled rotor.
Big brake kits & cross drilled rotors are over-hyped.
Brakes is another thing not to be cheap with.
Old 12-18-2003, 07:54 AM
Ricochet's Avatar
Banned
Yeah it's not like a spoiler where you can get a piece of crap and still be alright, brakes have your life in their hands..
Old 12-19-2003, 02:04 AM
so whatchu u guys are basically saying is that slotted rotors are the best in the realistic daily driver/race cars since they arent prone to cracking like drilled style rotors and better than conventional OEM rotors. Think i might invest my money into the Powerslot slotted rotors.
Old 12-19-2003, 02:22 AM
Slotted and/or dimpled would be more like a realistic choice.
Old 12-21-2003, 03:07 PM
mreff mreff is offline
ummm.... I don't know about you guys but I hate changing my brakes. and I'd really hate it if I had to do it like ever 6 or 7 thousand miles....
My 500ft/lb 450hp camero still uses flat rotors and stops just fine.
Changing rotors on 02 Outback` ecamc Outback 1 09-01-2009 07:32 PM
02 Silverado shakes when braking. kegster Silverado 17 07-17-2009 07:57 AM
Best place to buy Brake Rotors and Pads??? highlandlake Rodeo | Passport | MU 6 08-11-2006 06:56 PM
Best Brake Rotors and Pads ArLouJeep Grand Cherokee | Grand Cherokee SRT8 2 07-21-2004 01:49 AM
