Old 12-16-2003, 01:57 AM
taps65 taps65 is offline
vr4 tt intake help
installed a k&n intake fipk kit, checked all the harnesses, setup looked cool, BUT, ny car would hesitate when i accelerate and die when i idle. too much air volume? what can i do to remedy this and retain the cone type filter set up. thanks a lot.
Old 12-17-2003, 12:17 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
I've not heard of a car getting to much air volume from the filter. The description sounds more like its getting to much fuel and not enough air.
Sorry I don't have a solution off the top of my head. You may want to ask this over on the 3si site and see if someone there has ran into your situation before.
Resistance Is Futile (If < 1ohm)
Old 12-17-2003, 11:48 PM
Re: vr4 tt intake help
thanks yogsvr4, what minor mods can i do to my 94vr4 - what have you done to yours?
Old 12-18-2003, 01:23 AM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
besides intake; exhaust, stillen downpipe, and of course a boost controler. those are some nice basic gains. i havent got the downpipe yet cause i just don't' feel like taking it off when smog time comes.
Old 12-20-2003, 08:50 PM
stevo548 stevo548 is offline
Question Sorry bro you did something wrong
I have installed amany K&N FIPK Kits in 3000 GT's And Vr-4's. I have seen this problem only once and it was because the MAS honeycomb material was damaged before installation. However make sure your intake is working properly start your car and pop the hood. Then you can diagnos the problem if it's from the intake. Check the sounds coming from it, a vacuum noise should be coming from the filter. If you hear any whistling or lack of airflow there could be a problem either in your connection or as far up as the intake manifold or also with you make have broken your MAS airflow sensor. I highly doubt your engine is getting to much air that's next to impossible and plus with modern day fuel injectors instead of carbeurators, the amount of fuel injected and burned is all proportional to your air intake. However there is one way your engine can have to much air intake. This is if your fuel injectors are not working properly. It's a V-6 so make sure all 6 injectors are working properly. That's about all the help I can give I hope you fix the problem.
-Steve
What Is Vr4?? Please Help. mitzuchick 3000GT/Stealth 4 11-24-2008 10:14 AM
Home Depot Intake, tubes on the intake, HELP! Thor06 Off-Topic 6 10-25-2005 08:21 PM
VR4 Engine Help mixmastermike28 3000GT/Stealth 2 06-29-2004 09:08 PM
95 vr4 radio help =/ suk 3000GT/Stealth 2 12-15-2003 04:43 PM
