Old 12-15-2003, 10:44 PM
Frank1 Frank1 is offline
Thumbs up 92-95 civic jdm front fenders
Need a set of jdm front fenders to fit my 92 civic. Any leads would greatly help out to finish up the car. Thank you, Frank
Old 12-16-2003, 12:07 AM
Miataracer's Avatar
Miataracer Miataracer is offline
Send a message via AIM to Miataracer Send a message via Yahoo to Miataracer
Re: 92-95 civic jdm front fenders
what is the difference? the JDM ones have side markers or something? if that is the case just add side markers to the normal ones
LS1 RX-7 Zoom Zoom
Old 12-16-2003, 12:08 AM
Miataracer's Avatar
and welcome to the boards!
LS1 RX-7 Zoom Zoom
Old 12-16-2003, 09:07 AM
Re: Re: 92-95 civic jdm front fenders
The difference is that in Japan the two door and four door fenders are the same. They dont have different fenders like USDM. USDM fenders are longer in the rear and our two door fenders wont fit on a four door.
Thank you for your response, maybe others can learn this difference.
Old 12-19-2003, 08:59 PM
SP_Mark SP_Mark is offline
Actually if you want to get really technical..the fender are the same except for of cource the side markers. and if you're lucky, you can get a set of fenders with the thin side moldings still attached.
Old 12-19-2003, 10:59 PM
That is not true, I have a set of the USDM 2 door fenders and a set of USDM 4 door fenders and they are different, the rear is longer on the 4 door. The JDM fenders that I have now are an exact match in size as my 4 door fenders with the execption of the fender opening, the JDM has the opening of the USDM 2 door fenders so that a 2 door body kit will match up perfectly to the fender opening. I have a damaged JDM fender that I want to replace and it is easier to get a used one then to repair mine. Let me know if anybody has a set of used JDM fenders. Thank you, Frank
Looking for 92-95 Civic JDM Black Headlights Fo_SheeZy Exterior | bodykits | Lighting 1 03-21-2008 06:18 PM
92-95 civic oem carbonfiber fenders fs/ft jun_crack333 Classifieds 0 08-23-2005 09:47 PM
JDM ITR front end on 92-95 civic coupe Smokey4 JDM Motor & Parts info/chat 0 03-19-2005 11:22 PM
ISO 92-95 Civic fender trim Schweinhund Exterior | bodykits | Lighting 4 04-13-2004 11:14 AM
