Old 10-28-2003, 07:05 PM
crazyH crazyH is offline
jdm or usdm h22, help!!!!!!!!
Ok guys im very close to purchasing a 1996 prelude with a new h22 swap, The motor is claimed to a be a jdm h22 by the owner. How can i tell if it is j-spec or just a us version h22?? Also is there only one type of jdm h22a or is the type-s version have more horspower?? The only spec i know is that jdm h22's have 220hp and not sure about torqeu. if anyone has all the specs let me know!
Old 10-28-2003, 10:29 PM
hondaracer hondaracer is offline
Re: jdm or usdm h22, help!!!!!!!!
JDM specs for h22:
200HP JDM H22A
2157cc (2.2L) DOHC VTEC
200hp/161trq
10.6 Compression Ratio
Old 10-28-2003, 10:34 PM
Re: Re: jdm or usdm h22, help!!!!!!!!
Originally Posted by hondaracer
JDM specs for h22:
200HP JDM H22A
200hp/161trq
Are you sure! ive seen multiple times that the jdm h22 has 220hp! and the us version has 195 or 200hp
Old 10-28-2003, 10:55 PM
Re: Re: Re: jdm or usdm h22, help!!!!!!!!
Yes I'm sure but I too have seen that 220hp jdm h22 your talking about. There is two h22's I think. One of the jdm's has 200hp and the other has 220hp. That jdm h22 you've seen probably has a higher compression ratio than the one I just posted but that is facts what I just posted above. I got them off a website that sells just jdm engines.
Old 10-29-2003, 08:36 AM
93accordEX 93accordEX is offline
type s/euro r has 220 hp. most likely the car you are looking at doesn't have that unless they specifically mentioned it. the regular jdm h22 is pretty much exactly like the us, a bit higher compression, so thats why it makes a little more power then the US engines.
www.cb7tuner.com
Old 10-29-2003, 08:45 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
H22A
Displacement (cc): 2157
Power (bhp@rpm): 220@7200
Torque (ft/lbs@rpm): 163@6500
Compression Ratio: 11:1
Bore (mm): 87
Stroke (mm): 90.7
Cam Design: dohc
VTEC?: yes
OBD: 2
Year(s) Produced: 1997-2001
In the following car(s): Honda Prelude SiR (JDM)
Power (bhp@rpm): 200@7000
Torque (ft/lbs@rpm): 156@5250
Compression Ratio: 10.0:1
Bore (mm): 0
Stroke (mm): 0
Cam Design: dohc
VTEC?: yes
OBD: 2
Year(s) Produced: 1999-2001
Power (bhp@rpm): 190@6800
Torque (ft/lbs@rpm): 152@5500
Compression Ratio: 10.6:1
Bore (mm): 0
Stroke (mm): 0
Cam Design: dohc
VTEC?: yes
OBD: 1 or 2
Year(s) Produced: 1994-1997
In the following car(s): Honda Accord SiR
Bore (mm): 87
Stroke (mm): 90.7
Cam Design: dohc
VTEC?: yes
OBD: 2
In the following car(s): Honda Prelude Type S (JDM)
Power (bhp@rpm): 200@6800
Torque (ft/lbs@rpm): 161@5500
Bore (mm): 0
Stroke (mm): 0
Cam Design: dohc
VTEC?: yes
OBD: 1 or 2
Year(s) Produced: 1992-1996
In the following car(s): Honda Prelude VTEC
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 10-29-2003, 09:55 AM
badboycivic2003 badboycivic2003 is offline
this applies to e also as I am looking for a JDM H22. Where did you get yours from??
Also, I have always seen websites state that the JDM H22 is 200hp ...so the prelude sir has 220hp ....whats the difference between the two engines apart from power? I hve never seen the SiR prelude engine for sale anywhere on the net.
DO you know any websites that sell it blu civic??
Old 10-29-2003, 10:00 AM
BLU CIVIC's Avatar
調整器
guy over here is sellin one
http://www.dragva.com/forums/showthr...a&pagenumber=1
other than that...they go for about $2k on ebay
The name's Adrian
2011 CR-Z - Stock
Old 02-21-2004, 07:36 PM
steffear steffear is offline
I got my jdm b18c from hondamotorsonline.com but last time I checked the website was offline but I was very satisfied with quality of engine and shipping time, the only thing is I got a canadian tranny not jdm, but turned out to be better cause it has longer gears = better gas mileage on the highway.
Old 02-24-2004, 08:48 PM
mjline99 mjline99 is offline
Send a message via AIM to mjline99
does a h22a engine jdm/usdm either one. does ne body kno if any of the civics other engine parts(trans,ecu,harness,mounts,etc) will be compatible with either one of those engines.
Old 02-25-2004, 01:06 AM
deezzen deezzen is offline
i just got my h22 for my 2000 accord i heard the different between the to is that us redline at 7300 and jdm redline at 8300 i have also seen the type s the diff is high comp and a lsd trans but i pick my set up for 1800 hundred only all jdm from a 98
Old 02-25-2004, 01:21 AM
93hybridaccord 93hybridaccord is offline
To tell whether it is a true JDM h22, it will be stamped with just h22a. If it is a usdm, it will be h22a1 or h22a2. Either way, it will have a number after the letter a. The JDM block doesn't have this number. Also, if you'd like to know what year the engine is, look at the head itself. You'll see 3 circles with numbers and arrows in them just between the 1st, 2nd and 3rd exhaust ports. The middle circle will have 2 numbers. The first will be a 9 and the second will be whatever. For instance, mine says 9|2. That means 1992. it also shows the month it was made. Everyone else is correct as far as hp numbers.
MJline99, as far as I know, the tranny and mounts will not work. From what I understand though, some years of hatches with h22's use gsr axles, unfortunately, I don't know which. Ecu's and harnesses, your guess is as good as mine, but I could find out if you really need it.
93 accord - jdm h22a
2003 srt-4 - daily driver
Old 02-25-2004, 06:15 PM
thanks 93hybridaccord no need to find out for me
Old 02-25-2004, 06:19 PM
some other forums have been saying that its not a good idea to turbo a h22 engine becuase it mostly results in a blown engine. another thing what do u think would be the best engine in a 98 civic for easy installation(compatible parts like tranny),cheap and best results.
Old 02-26-2004, 12:09 AM
You can turbo the h22. It's all about tuning and how you build it. The b16 is probably your best choice.
