Old 12-14-2003, 07:07 PM
alphalanos alphalanos is offline
Installing RF Amp Kit--need help
So far all I have done is run RCA's. Im really cautious so I'm just going to list the parts of the kit and you guys tell me where they go and how to do it. im assuming all of these.
Black Wire- Ground (to neg terminal and/or frame?)
Red Wire- To pos. terminal. (do I just drill through the firewall?)
Blue wire- Antenna/amp lead(amp turn on, can i cut the deck's connector off and just twist the amp lead to it?)
any suggestions on placement or anything else would help alot. or if i have forgotten anything.
96 EJ6. Future home of boosted B18C1.
Old 12-15-2003, 12:09 AM
Diesel2NR's Avatar
Diesel2NR Diesel2NR is offline
Send a message via AIM to Diesel2NR Send a message via Yahoo to Diesel2NR
You're correct on what all the wires are. With the ground, you want to try and keep it as short as possible in distance. You should put it around a bolt or something that connects with bare metal. Seat Belt Bolts work really well for this; they're hidden and provide good contact. The red power wire should be run to the positive terminal of your battery. If you can't find an unused hole big enough, you'll have to drill. Make sure you check both sides of the area you're drilling to make sure you don't hit anything. Get some silicone sealant and put it around the wire once you have it run to seal out air and moisture from getting into your interior. For my remote line (the blue one) I just soldered in into the same place where I soldered the lines from the head unit and wiring harness. Hope this helps!
Old 12-15-2003, 01:11 PM
Can I just buy an Optima battery, put it in my trunk, and hook my amp to it.
Old 12-15-2003, 01:34 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Installing RF Amp Kit--need help
yes, but you'll still have to run a 0/1ga wire connecting the + terminals of your batteries, which means you still have to route the power cable, still have to go through the firewall, etc. Just this time you'd be doing it with bigger wire, making things harder.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 12-15-2003, 02:06 PM
so can i cut off the head unit's antenna lead and twist it together with the amp turn on lead?
Old 12-15-2003, 04:06 PM
sr20de4evr's Avatar
As long as the antenna lead doesn't turn on anything else in the car that would be fine.
'01 Black Sentra SE
'05 Silver WRX STi
Old 12-15-2003, 06:03 PM
MStout's Avatar
MStout MStout is offline
Why not just run the power cable in through the wire guide in the door hinge area and into the car...under the trim and all. Thats what my bro did and you cant see the cable anywhere but when you open the door and it sticks out of the little black rubber wire housing.
Old 12-15-2003, 07:26 PM
sr20de4evr's Avatar
Not every car has that
'01 Black Sentra SE
'05 Silver WRX STi
Old 12-15-2003, 09:53 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
NO .... the antenna lead only supplies power when the radio is turned on, the amp turn on stays on with the head unit.
Old 12-15-2003, 10:23 PM
sr20de4evr's Avatar
Re: Re: Installing RF Amp Kit--need help
really? I didn't know that
'01 Black Sentra SE
'05 Silver WRX STi
Old 12-16-2003, 07:18 PM
hold on maybe i wasnt clear enough. all im doing is cutting off the metal peice that crimps the wire. twisting the wires together instead of actually plugging them together like there supposed to has the same effect as making metal to metal contact beween 2 connectors. think of regular car speakers and how they have a crimped wire with the metal tab that slots onto the speaker tab.
Old 12-17-2003, 05:33 PM
Audio Guy
Re: Re: Re: Installing RF Amp Kit--need help
yep, it's a common problem ...... what happens is, the amps cut off when you turn the CD on (radio off).
Need help with tachometer install! AHHKILLA Eclipse 2000+ 0 05-03-2009 10:04 PM
Installed new distributor need help yruyur General Discussion 4 02-21-2004 04:43 PM
Installing Integra seats need help. zigen '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 5 03-23-2003 07:02 PM
TURBO KIT - NEED HELP on REVHARD & DRAG3 KanClan2002 Forced Induction 0 10-06-2002 03:42 AM
Just installed new headers, Need Help! out-law '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 7 06-02-2002 04:27 PM
