Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 12-14-2003, 04:17 PM
Ford_Girl83 Ford_Girl83 is offline
Fuse Help
Hi my name is Crystal!
I drive a 1993 Ford Exporler, i bought it used so it did not come with an owners manual. My blinkers suddenly stopped working, and i was wondering if anyone out there could tell me what number fuse i would want to replace or send me list of fuse numbers and what they correspond to. Thank you soooo much!
Old 01-01-2004, 06:14 PM
KATAZ's Avatar
KATAZ KATAZ is offline
Send a message via AIM to KATAZ
Re: Fuse Help
fuse List For 4.3 V6 Ford Explorer 1991 - 1995
1. Stop Lamps, Hazard Warning Lamps, Speed Control Inhibit - 15 Amp Fuse
2. Horns -20 Amp Fuse
3. Lighter, Flash To Pass, Power Lumbar, Multifunction Switch - 20 Amp Circuit Breaker
4. Instrument Panel Illumination - 10 Amp Fuse
5. Premium Radio Amplifier, Trailer Tow - 20 Amp Fuse
6. Power Windows - 30 Amp Circuit Breaker
7. Anti-lock Brakes Module - 20 Amp Fuse
8. Ego Sensor Heater - 10 Amp Fuse
9. Cluster Warning Lamps, Electronic 4wd - 15 Amp Fuse
10. Speed Control Amplifier, Radio - 15 Amp Fuse
11. Park / License Lights - 15 Amp Fuse
12. Blower Motor - 30 Amp Fuse
13. Turn Signals, Back Up Lights, Rear Defroster - 15 Amp Fuse
14. Dome / Courtesy Lights / Power Mirror (1992 Two Door Only) - 15 Amp Fuse
15. Rear Window Washer And Wipers - 15 Amp Fuse
16. Air Conditioning Switches, Compressor Clutch - 10 Amp Fuse
17. Front Washers And Wipers - 6 Amp Circuit Breaker
Old 01-23-2004, 04:20 PM
Ford100 Ford100 is offline
Hi,
I have a similar problem. My right blinker is not working. Do I just need to change the bulb or the fuse? Also, where is the fuse box and how do I open the tail-light to replace the bulb.
Thanks,
PLZ help 94 grand am ignition fuse keeps blowin! thewizard67 Grand AM 7 05-03-2014 08:46 AM
2000 IG ignition fuse blowing...Please help!!! stanley24538 Metro 5 04-24-2010 10:18 PM
98 Camaro electric and fuse issues Rkeefer23 F-Body Problem Diagnosis 2 12-20-2009 02:00 PM
blowing fuel pump fuses!! help! '98 slt importeater38 Yukon 8 12-08-2004 08:02 AM
'92 Lude blowing fuses...HELP!!!! stickboy707 Prelude 5 08-06-2004 10:15 PM
