Old 12-13-2003, 04:05 AM
Deniz Deniz is offline
Check engine light
Check Engine light comes up every once in a while when i am driving on the highway. not all the time once in a while and it stays on till i shut off the engine.all the fluid levels look fine.
sometimes it doesnt come on at all..
There is no powerloss or rough driving. what do you guys think might be the problem and how to get rid of it.
Some kind of clicking sounds comes from the engine once in a while till the engine warms up.
any help is appreciated
thanks
Old 12-13-2003, 10:29 AM
firechicken1986 firechicken1986 is offline
Re: Check engine light
You should check for engine codes.If you have shop manual for your vehicle. If you have dodge you can cycle the key on then off About 8 or 9 times then leave in the on postion you will see a light flashing on your dash count the flashes NOTE you will see pauses in the flashes write down the codes look in manual for that code it should tell you whats wrong. Or take in have a mechanic use a code reader Or you could by your own reader for about $30
Old 12-13-2003, 02:06 PM
i just checked the codes and its like this;(I, means a single blink, and - means a pause)
III-III (air conditionning clutch relay circuit)
II-IIIII(automatic idle speed motor circuits)
IIIII ( i have absolutely no idea)
what are these suppose to mean and what should i do?
thanks
Old 12-14-2003, 07:01 AM
The Idle speed motor circuits. Could mean T.P.S.Which is a trottle postion sensor and if it has an intermittent problem will cause the check engine light to come on. Try unhooking the battery for about 1/2 hour these might be old codes this should erase the codes. hook it back up drive and see if the light comes on. if it does check the codes again see if they are the same . Good luck.
Old 06-20-2004, 11:47 AM
paseaal paseaal is offline
can someone help me with y i have a sudden power loss on my caravan.drives fine until it warms up and then suddenly dies down like its out of gas or something.
paseaal
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 10:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 06:40 AM
