Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 12-12-2003, 11:36 PM
spssr20de spssr20de is offline
Angry help 2000 sr20de chokes and stalls
need help guys 2000 sr20de 72k, complete tune up, new o2sensor, revs fine over 2500rpm as soon as it drops below that chugs and will not excelerate. then chugs itself to a stall. slight smell of gas by the fuel pressure regulator. but checked and is fine.
Old 12-19-2003, 06:24 PM
mreff mreff is offline
Re: help 2000 sr20de chokes and stalls
Hmmm, interesting. Well, it would help if I knew anything you had done to the car recently, and why you replaced the o2 sensor. If your o2 sensor was fouled you might be running rich. If this was the case, now that you have a new o2 that works, it is probably telling your computer to lean out the mixture. I don't suppose that fuel pressure regulator you spoke of is adjustable. You're playing with fire when you adjust those. or it could just be a problem with your MAF/MAP or your CTS which are also key factors in how much fuel the engine gets.
2005 stalls and stalls and stalls... MN Ding Dong Focus | C Max 3 06-27-2011 07:52 PM
2000 Grand am se...bad idle and stalls weis_01 Grand AM 3 09-19-2010 11:50 PM
95 tsi really low idle and stalls.. Please help please Brenthb25 Eclipse Problem Diagnosis 3 07-20-2010 10:41 PM
fuel smell in car and stalls sometimes? HELP mark4674 Taurus | Taurus Wagon 0 12-19-2009 07:08 PM
94 oldsmobile 88 royale I need help with its choking and dieing woodscf Eighty Eight 4 01-27-2005 10:55 PM
