Old 12-12-2003, 06:14 PM
Sugarlow Sugarlow is offline
Question Timing Belt Cover
I believe oil is leaking from the timing belt cover. Do I have to take the inner wheel well out to get to it, or does any onehave any easier suggestions?
Old 12-12-2003, 06:19 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Re: Timing Belt Cover
There shouldn't be any oil coming from the timing cover. If its toward the top it's probably the valve cover gasket. If its in the middle, probably the head gasket. At the bottom, main seal. Those are some of my opinions. I may be wrong though.
Check out my car here My 91 Hatch
Old 12-12-2003, 06:29 PM
Thanks for the input. I guess I am going to have to have a closer look at exactly where the oil is coming from. Mayby clean it up and wait for the leak to happen.
Thanks
Old 12-12-2003, 07:12 PM
cot's Avatar
cot cot is offline
The thing is, there really shouldn't be any oil in there at all to "leak" out, so you probably need to take off the cover to get to it
I believe you need to take the valve cover off to get the top part of the timing belt cover off, then you may be able to get a better idea what's going on. It's fairly likely that it's leaking at the edge of the valve cover anyways, so if you pull it off you can see what the gasket looks like and replace it.
but if you're seeing oil actually come out of there, i'd assume the problem is a bit more gross than you're seeing, since it's reallly leaking from something another layer in.
I think once the top part of the timing cover is off you may be able to get the rest of it off without removing the wheel/splash shield, but i'm not positive.
All I know is there's a back piece to the cover that you have to put on before you put on the timing belt, and i found that out the hard way (didnt even think about the timing belt cover till after the new belt was already on) But you shouldn't have to take that bit off to see the leak.
Old 12-12-2003, 09:49 PM
Is it possible that the leak is actually coming from the oil pan and getting "splashed" upward. I ask this because I see some "splashing" of oil on the underside of the hood (not alot) and "splashing" forward toward the radiator (again not alot). So I guess my question is.....could the crank pulley be "splashing" the oil upward since it turns clockwise (I believe)??
Old 12-12-2003, 10:04 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
There is a small drain in the bottom of the timing belt cover but I don't know if any fluids coming out of the drain will hit the crank pulley and cause the fluid to be slung around.
Listen to the others, take the upper cover off and all will become clear.
BTW, if it is your front main seal you will have to take the wheel off, remove the inner splash guard, take off the belts, take off your crank pulley bolt (with a big impact wrench), remove the crank pulley (don't lose the drift key), remove the timing covers, releave the timing belt tension, remove the bottom timing sprocket and there will be the $6 part you need to replace. Also while your there you should replace the timing belt and water pump if they're old. GL
Old 12-13-2003, 12:08 AM
BullShifter's Avatar
this should help during the process if you dont already own a good manual : http://www.binghamtonlife.com/manual/2gsm/default.htm
Old 12-13-2003, 12:54 AM
cot's Avatar
cot cot is offline
yeah, though he should seriously buy a helm if he's gonna get that far into it
i never woulda gotten mine back together with so few leftover pieces without it!
Old 12-13-2003, 03:52 PM
That link is for a factory repair manual (Helm) - it may not be for the right model, but 89-91 Civic/CRX is pretty much covered.
Old 12-13-2003, 04:03 PM
cot's Avatar
cot cot is offline
Yeah, but i think if you're gonna get into it, a paper copy you can work with is invaluable
Old 12-13-2003, 04:05 PM
Re: Re: Timing Belt Cover
but if no manaul is available the online version is better than any Haynes or Shitlons
Old 12-13-2003, 07:44 PM
Magik Si's Avatar
Magik Si Magik Si is offline
Ummm...isn't there an "o" ring at the end of the cam shaft in that area (correct me if I'm wrong - cam shaft seal) that holds oil from escaping in that area?
I could be wrong...but the description of the problem is sparking a memory...
Jason
www.jasonlorette.50megs.com
90 Civic HB Si - D15B1 + MPFI
How to change timing belt? RainSpirit44 SVX 2 03-25-2009 04:30 AM
timing belt covers/valve covers 1PhatCX '88 - '91 Civic | CRX | Wagon | Shuttlee 11 10-30-2004 08:16 PM
Timing Belt Covers JOnEB4EvR Off-Topic 5 12-13-2003 12:28 AM
Timing Belt Cover Pimp_87_CRX '71-'87 Civic | CRX 0 11-08-2003 07:48 PM
timing belt/cover for DOHC ZC 94tegRS Engineering/ Technical 0 07-06-2003 10:38 PM
