Old 12-12-2003, 03:07 PM
pharma_salameh pharma_salameh is offline
Chevy Cavalier 1999 Won't Start
Hello,
Yesterday, the ABS light came on in my Chevy Cav 99' (67K) and stayed on, I restarted the car and the light went off. I drove home and parked for the night, it was pretty cold last night low 20's, in the morning I tried starting the car and it won't start, it did not give any crancking noise, it was just some clicking when I put the key to ignition position, a friend tried to jump start the battery but with no use the car won't start. I noticed that the panel lights (breaks, oil, air bag etc...) go on and off when I turn on the key to the ignition position, please do you have any idea what is the problem, do you think it might be the battery? we changed the ignition module about 2 weeks ago.
Thanks for you help in advance
asd
Old 12-12-2003, 10:04 PM
TEXAS-HOTROD TEXAS-HOTROD is offline
Re: Chevy Cavalier 1999 Won't Start
Need to turn on the headlights and turn the and watch the lights to see if they go dim.
You might want to connect a set of jumper cables to a vehicle that is running and let it charge the Cav. for a while. Then see if it will crank over. Sounds like the battery to me.
---TEX---
Old 12-13-2003, 04:28 PM
99ssconv 99ssconv is offline
check for bad connection at positive battery cable from acid corrosion
Old 12-14-2003, 09:26 AM
wanacavy wanacavy is offline
try putting your friends battery in your car for alitle whiel and see if it starts if not its not your battery somethign else coudl be wrong
Old 12-15-2003, 03:57 PM
Problem Solved!
Thanks guys, it was the battery. I got a new one with 690 cold cranking amp, and it is working just fine,
thanks again,
96 Cavalier won't start/stalls when boosted xcooneyx Cavalier Problem Diagnosis 0 01-15-2011 01:03 AM
1999 GrandAm 3.4L Won't Start Jeepx4 Grand AM 10 08-10-2010 03:43 PM
2002 Chevy Suburban cranks, won't start adamj_rogers Suburban 1 06-17-2010 07:34 AM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
1999 Cavalier LS Won't Start - Maybe Alternator? millie08 Cavalier Problem Diagnosis 2 08-05-2008 01:16 PM
