Old 12-11-2003, 11:15 PM
tom_indo tom_indo is offline
Send a message via AIM to tom_indo Send a message via MSN to tom_indo Send a message via Yahoo to tom_indo
Angry wont fire
i ran around town today and came home. a couple of hours later i went out and turn the key and the motor turns over strong but it does not fire. i start it everyday with out ever touching the gas and i did not touch the gas this time either. just turns and turns. so i tried the gas and still nothing. what is wrong? i have checked the fuses. they are good.
Old 12-18-2003, 09:30 PM
loy loy is offline
Re: wont fire
electronics in distributor are probably bad
Old 12-21-2003, 11:37 AM
darrellndeclan darrellndeclan is offline
Send a message via Yahoo to darrellndeclan
Re: wont fire
I would also check the ignition coil if you can not find anything wrong with the distributor. I had a similar problem and it turned out to be the pick up coil inside of the distributor. Also make sure some of your connections did not rattle loose.
Loony ignition wont fire blazeron32s S-10 15 10-12-2004 07:23 PM
Chevy Astro wont fire mtngoat167 M Bodies 6 05-26-2004 01:12 AM
2000 jgc limited --turns over but wont fire-- wait 1 hour then fires!! andybair Grand Cherokee | Grand Cherokee SRT8 0 05-18-2004 09:40 PM
1996 cranks but wont fire GreatCanadianMoose Jimmy 5 03-02-2004 10:12 PM
95 4x4 s-10 blazer turns over wont fire pd89ace Blazer 5 02-14-2004 11:20 AM
