Old 12-11-2003, 09:04 AM
Michael Wright Michael Wright is offline
Rear differential leaks
I have a '96 2 wheel drive suburban that runs low on rear differential gear oil about every 12000 miles. I can tell its low because I start getting the drivetrain bump that I've read about in so many posts.
Once I top the level off the bumping stops. What is causing the loss of level? There are no leaks visible on the differential or on my driveway.
Old 12-11-2003, 12:54 PM
platter platter is offline
Re: Rear differential leaks
I had a similar problem but with a Chevy van. Differential gear oil was leaking into my brake drum via the axle seal. I would remove the rear drums and inspect if you do not have any external signs.
Rear differential leak AlphaCrow Liberty 0 11-27-2010 03:17 PM
2005 300 Rear Differential leak rbeatty 300C | SRT8 1 01-23-2006 07:10 PM
rear differential leak cactuar167 Grand Cherokee | Grand Cherokee SRT8 6 08-23-2005 02:25 AM
rear differential leak K15004X4 C/K 7 04-22-2005 08:08 PM
Rear differential leak Matthew12M C/K 7 10-28-2004 02:38 PM
