Old 04-18-2005, 06:35 PM
K15004X4 K15004X4 is offline
rear differential leak
Does anyone know of a quick and easy way to stop a differential leak? The leak is above the fill line, so it only leaks immeadiately after I have been driving it. It only leaks a very small amount each day - it is more of an annoyance than anything. I have tried a "stop leak" additive but it has not worked. Any ideas?
Old 04-18-2005, 09:10 PM
Silverado Brethern's Avatar
Silverado Brethern Silverado Brethern is offline
Re: rear differential leak
Where specifically is it leaking out of the differential?
"Never under estimate the power of stupid people in large groups."
1997 K-1500 Silverado Vortec 350...125,610 and wounded
HD chassis package
Custom TRUE DUAL exhaust with cut-outs and Flowmaster 40 series mufflers
Poweraid Throttle Body Spacer
Custom Ram-air Intake with K&N FIPK GEN II
TFES Performance 3" Suspension Lift
Dual Air-Horn Kit with Compressor
Bed-Mounted 48" Hi-Lift Jack
Cobra Laser Radar Detector
285/75/R16 Cooper Discoverer STT's
1/4 Mile 10/15/05: 16.43 @ 91mph
Old 04-19-2005, 06:47 PM
It is leaking between the cover and main housing. The leak is above the fill line so while it is parked it does not leak. When I drive it, oil must splash around inside the differential and leak out through the seam. As soon as it is parked it will leak a few drops of oil and that's it. It is not a big problem, I am just getting tired of all the marks on my driveway.
Old 04-19-2005, 06:59 PM
Mine had a similar problems before and I just drained (syphoned) the fluid out and put new in and it hasnt leaked since. I'm pretty sure the origional problem was due to a cracked rubber washer or gasket on the front side of the diff. but to fix it i would have had to remove all the gears to get to it. So I figured its not worth all that just for a few stray drips.
HD chassis package
Old 04-19-2005, 09:15 PM
amac209 amac209 is offline
Send a message via MSN to amac209
take off the cover, scrape off the old gasket and either put in a new gasket or spread rtv sealant on the mating surface & put it back on. not a big job. you will need almost 3L of gear oil to refill the diff
Old 04-20-2005, 12:58 AM
Wheeler88's Avatar
Wheeler88 Wheeler88 is offline
Have you tried re-torquing the bolts with the diff at operating temperature?
88' Chevy K1500 Silverado
350 V8 5.7
Original Owner
77,000 miles
2nd tranny
Peeling Paint - Defective Factory Paint
235/85/16 BFG MT
Old 04-22-2005, 04:58 PM
goinbig goinbig is offline
Send a message via AIM to goinbig
put on a new gasket. That's why it's leaking.
Like someone else said...buy a new gasket and apply RTV to it and put it on. Or, just use RTV alone.
Old 04-22-2005, 08:08 PM
J-Ri's Avatar
J-Ri J-Ri is offline
RTV sealant alone is the way to go. Just make sure you get it on evenly, and in a 1/8" bead. Put the cover on with the sealant on it and tighten the bolts just barely tighter than finger tight. After a few hours, torque them down. Wait as long as you can to fill the diff. If the timing allows it, I like to let it sit overnight before filling it.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
