91 automatic trans.
I swapped a 90 2.9 from a 5speed into a 91 3.0 auto and am having trouble connecting the elec. to the tranny. I had to keep the 90 wiring harness and it dosen't match the 91 trans. I"ve tried looking up different wiring diagrams and thought I had it figured out but only successful in getting backup lamps to work. Car runs drives ok but no overdrive or neutral saftey. Thank. RangerMike.
Re: 91 automatic trans.
sorry mike,considered not interchangeable,because the 3.0 tranny runs through the computer.either have to put the 3.0 engine in with it along with the computer and wiring harness from bumper to bumper,not feasable. best bet is to find a tran. from a 2.9 found in 1986-90 ranger/bronco.you can adapt the back up light wires but not the OD. I once put a 4.0 in a 86 bronco.it was a major job,but you got to keep the like eng/trans/wiring harness/computer together.i'll reasearch my wiring diagrams and get back at you.
Re: Re: 91 automatic trans.
If the overdrive is controlled by a solenoid in that automatic You could just hook up a switch and click the overdrive in whenever You want it. Some automatics also have lockup, and it can also be put on a switch.
