Old 05-07-2003, 11:52 PM
rupert e. rupert e. is offline
Exclamation Automatic TRans. problem?
MY 94 A/T Accords' instrument panel is blinking the D4 or drive 4 light 5 mins after is start the car. I read the owners manual and it says that its probably a problem with The A/T. when i drive there seems to be nothing wrong, I already changed the fluid.. any info? Tnx
Old 05-09-2003, 05:44 PM
lorunner lorunner is offline
there are many solenoids on the trans if one of them are malfunctioning then they will tell the pcm to flash the D4 lit you may not feel anything because it may be intermitant.
Old 05-10-2003, 10:35 AM
hondaman-iac's Avatar
hondaman-iac hondaman-iac is offline
Send a message via AIM to hondaman-iac Send a message via Yahoo to hondaman-iac
just find the ecu blue connector and short that, then put the ignition in the run possition and it will blink you the codes on the d4 light the same way the cel blinks if the ecu is trowing a code. i had the atcu codes here somewhere but i need to find them. mine trew codes at one time for the solenoids then i tested them for resistance and if they were clicking and i found out they were perfect. i just used some electrical connectore cleaner and cleaned the contacts, then i never had a problem since.
Stefan
hondaman-iac @ HondaStyle
92 ACCORD LX -- powered by a blown F22A1
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
*Ground Control coilovers
*Energy suspension bushing kit
*front upper strut bar
*rear upper strut bar
PureHonda member since April 2001
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
