Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 12-10-2003, 12:20 PM
FrancoT FrancoT is offline
Angry Can't Stop the Squeak!
My GOD!
The squeak is getting worse and worse. Its definitely metal on rubber. I had a bushing replaced, the others don't seem worn. Anybody else have this noise when turning right? Is there any quick solution?
PLEASE HELP.
Old 12-10-2003, 04:00 PM
dafrazi dafrazi is offline
I have a clunk at low speed right turns. I have done everything but replace the control arm bushing. Friend of mine has a '97 Aurora that had a squeal...he had to replace the bearings. The squeal also may be caused by a dry Cv joint. Look at the halfshaft and see if there are any splits in the boots that cover the CV joints. Replacing the halfshaft isn't too bad. You can buy a remanufactured one relatively inexpensively. It's hard to diagnose squeaks without hearing them.
Old 12-10-2003, 05:12 PM
dmorlow dmorlow is offline
it's the control arm. one of the bushings fell out. it happened on my car. same exact symptoms. only when turning right.
Old 12-11-2003, 06:13 AM
bustedratchet bustedratchet is offline
Re: Can't Stop the Squeak!
My car made a metel to rubber squeeking noise while driving. I noticed it more going slow and could get it to go away sometimes. It wasn't constant it squeeked for every revolution of the tire. It drove me nuts. I did discover finally it was the drivers side tire squishing against the wheel.
Can't stop the heat cedarjames Problem Diagnosis 2 07-08-2009 06:13 PM
I can't get the oil pan plug aft of the dipstick tube to stop seeping... Cobra4B GTRA / GTWS / GTS 2 05-19-2009 08:14 AM
Can't Stop Drawing-Broke out the INK GirlBear Sketching and Drawing 12 05-01-2005 12:53 PM
