Old 12-09-2003, 06:02 PM
hatebreeeder hatebreeeder is offline
Send a message via AIM to hatebreeeder
Question Anyone know why. . .
. . .my IROC stalls when I give it gas? I can start it with a jump since the battery is almost completely dead (I just bought it) but when I gas it it stalls out. It's 86 with TPI. Could it be a sensor or a battery problem?
Old 12-09-2003, 06:23 PM
1992RS 1992RS is offline
Send a message via Yahoo to 1992RS
Re: Anyone know why. . .
Sounds like a computer problem to me. Check your throttle position sencor. When you hit the cas the tps sends a signal to your computer telling it to advance the timing a fuel spray, it may not be advancing the spray. So what's happening is your timing is advancing but your engine isn't so it's gonna die. Some one let me know if I'm wrong, I don't want to be giving missinformation.
Old 12-09-2003, 06:27 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
im thinkin that your mixture's screwed up...check your o2 sensors
Old 12-09-2003, 06:32 PM
I've had o2 sensor problems before and never caused me to stall. But hey, it could happen. But still check your throttle possition sensor.
Old 12-09-2003, 06:35 PM
Checking the o2 and tps sensors sounds good. the tps is 50 bucks new. But it couldn't possibly be a battery problem?
Old 12-09-2003, 06:38 PM
Actually, how would I got about checking the sensors? How can I tell if they're bad or not?
Old 12-09-2003, 06:39 PM
Also, we tried changing the computer. It wasn't that.
Old 12-09-2003, 06:43 PM
Is your check engine light comeing on? Try running a diognostic. If it's an o2 sencor you'll get a 13 I think.
Old 12-09-2003, 09:44 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
um, why is the battery dead??? is your alternator crapped out? if you dont have any juice, when you stomp it, your gonna basicly blow out your candles aka sparkplugs. also, do the basics, check all your wires, make sure they are set up right, your coil could be bad, look in your distributor cap and look for arcing or carbon scoring out of normal ammounts. might just need a tune up. also, check your timing. alot of people dont set the timing correctly, in other words, they dont disconnect the "set timing connector" and set the timing with the computer still trying to correct. dis conncet that connector, and make sure your base timing is right.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 12-09-2003, 11:23 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Re: Re: Anyone know why. . .
Ill bet you ten bucks that what it is my buick did that and it took me forever to figure the damn thing out. start it and then unhook the jumper cables, but don't whack the throttle. just let it idle. if it sputters then dies ( almost seems like is ran out of gas.) its your alt. Another thing to do is to start it up and disconnect the battery. If it dies then you know that it was depending on the battery for spark. If it does not die then then you know that your charging system is doing its job.
later
andy
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 12-10-2003, 02:44 PM
id run with the alternator idea, otherwise grab your multimeter and start checking resistances on the sensors
Old 12-10-2003, 02:48 PM
RABarrett RABarrett is offline
I believe the alternator problem is the way to start. I suspect you may have a dying fuel pump as well, but until the operating voltages in the system are correct, you cannot check it anyway. Ray
Old 12-10-2003, 11:23 PM
Murco's Avatar
Murco Murco is offline
Maximum Car Guy
Send a message via Yahoo to Murco
It's your alternator, but don't disconnect the battery while the engine is running... See your other post for why...
My AF Classic Model Car Gallery
Old 12-11-2003, 11:03 AM
StingRay_68 StingRay_68 is offline
I removed the battery cables while it was running on my vette... yeah, bad idea. Fried my alternator, and took my tach with it. Tachs are expensive to fix in old cars like that =(
Anyone know why production stopped? AmErIcAnMuScLe813 F1 9 07-09-2006 02:15 PM
Does Anyone Know Why.... BrentCosenza Neon | Plymouth Neon 18 04-05-2005 10:09 PM
Anyone know why our Sigs, are messed up? ShOrtyOC714 Hot and Not 6 09-27-2003 12:51 PM
AC fan makin noise, anyone know why? AtomAton '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 6 07-02-2003 12:53 PM
fuel cut-off at 3500 on new ZC motor!!! Anyone know why ?? 92teggsr Engineering/ Technical 5 03-27-2003 07:38 PM
