Old 12-09-2003, 02:02 PM
KSC KSC is offline
2000 four 4 wheel drive turning problem
2000 k-1500 4x4 has resistance at front wheels when turning. It will bring the truck to a stop when turning without offering more pedal power. Feels like CV joints, but I figered they moved and flexed with 4 wheel drive on or off??? Has any one heard of a common problem with 4-wheel drive and turning?
Thanks, KC
Old 12-09-2003, 02:04 PM
KSC KSC is offline
Re: 2000 four 4 wheel drive turning problem
To make it clear....This only happens when truck is in 4 wheel drive.
KC
Old 12-18-2003, 05:05 PM
gomrac gomrac is offline
If driving in 4x4 drive on dry hard surface it will always do that and is not good for the front axle. There will be some noticable diffrence even if in snow, mudd, etc. . If it is really bad in wet conditions, you need to inspect the cv boot to make sure you are not losing any grease. If so you may have tore up the cv joint. Hope that helps.
Happy Jack
all wheel drive is hopping on pavment like its in four wheel drive on sharp turns kenevile333 Explorer | Explorer Sport Trac 0 04-18-2008 05:55 AM
95 GC, "Part Time" light sometimdoes not turn on when engaging four wheel drive (4WD) murpht3 Grand Cherokee | Grand Cherokee SRT8 0 01-26-2005 05:28 PM
Changing from Two Wheel Drive to Four Wheel Drive mandymelville-love Bongo Friendee 0 04-07-2004 06:17 AM
Four Wheel Drive Problem revump S-10 1 01-24-2004 05:56 PM
2000 four 4 wheel drive turning problem KSC C/K 2 01-22-2004 11:27 PM
