Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 12-09-2003, 01:28 PM
jermmcd jermmcd is offline
OBD and how to access
Hi all, is there any easy way to access the OBD codes for a 1998 Dodge Ram 1500 4X4? It feels like the oxygen sensors are faulty (I had that problem with my 1995 & 2001 Plymouth Neons). on my previos cars, I could access the Self diagnostics by turning the ignition switch on-off-on-off-on and it would tell me the codes to the problems that the cars were having. Is there something like this for the 1998 Dodge Ram trucks? An help is greatly appreciated!
Old 12-11-2003, 02:17 PM
Sport45 Sport45 is offline
Re: OBD and how to access
1996 and later models are equipped with OBDII systems. Check the emissions label under your hood to be sure. OBDII requires a compurer reader to pull and reset codes. The Autozone stores in my area will pull the codes for free.
Old 12-11-2003, 02:29 PM
Re: Re: OBD and how to access
Thanks! I did go by Autozone yesterday. My check engine soon light flashes, especially going up mountains, or trying to pass some one. But as soon as I let off the gas, the light stops flashin and doesn't come on again. The man at autozone scanned it, but it passed. There is definately something wrong, and it feels like O2 sensors?!?! Any suggestions?!?!?
Old 12-15-2003, 11:12 AM
Mtngoat Mtngoat is offline
I have used EASE diagostics (www.obd2.com) while I am driving to detect problems. It is an expensive tool ($300), but worth while when you run into as many problems as I do. I have it connected to a laptop and recording specific data while driving. A second option would be the Data-Logger. This would allow you to record everything going on when you get the fault/check engine, and not need any other tools.
I prefer the laptop so the passeger can be checking all systems while driving. Again, not a cheap option, but worth it if you have access to a laptop computer.
Old 06-06-2004, 08:46 AM
sadlerb_98's Avatar
sadlerb_98 sadlerb_98 is offline
Send a message via Yahoo to sadlerb_98
2001 Ram. I did the on off on off on thing and in the odometer section it said " P done" and gave 6 chimes. What does this mean?
Thanks,
Bob
Old 06-06-2004, 10:51 PM
seniorbigs seniorbigs is offline
You will have a code for a cylinder misfire if the CEL is flashing. The fuel not burning in the misfiring cylinder gets passed into the cat and is burned there. This drives the cat temp way up and destroys the cat. When the CEL flashes, the engine is supposed to be shut off to prevent damge to the cat. That way, Chrysler might save on the cost of a cat.
P135 OBD code - what is it and how do i correct it. tiso_us Tracker 0 05-25-2009 04:49 PM
obd 2 codes and how to fix them tombunch Grand AM 1 05-21-2008 05:05 PM
OBD and OBD II software question Caballero Silverado 4 07-18-2007 09:29 PM
**List Of OBD I Codes and How To Retrieve Them** blazee Camaro Discussions 5 07-13-2005 09:14 PM
Where is multi-remote control unit? And how do I get access to it? amdana007 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 17 10-22-2002 12:37 AM
