Old 12-09-2003, 12:22 PM
Bilson8tor's Avatar
Bilson8tor Bilson8tor is offline
Send a message via AIM to Bilson8tor
f'ed up STD headers
I've got a 91 STD, and i was looking a the manual for my car, when i came to the exhaust system part i realised that they for some reason made the CANDIEN STD different than all the rest! why would they do this?
i was wondering though if i would be able to completely swap out this exhaust(headers,pipes,cat converter,tip) and put in one from some aftermarket system? i looks like all the holes line up and everything but is it going to fit around the engine and stuff like that?
and if someone can come up with a reason why they would make this model different than all the rest?
Old 12-09-2003, 12:30 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
well...what exactly is different?
..if you relocate the cat.. you'll be fine to rework the exhuast system..just get an aftermarket exhaust, aftermarket cat or si/dx cat, and a header and you'll be set
SOLD!
Old 12-09-2003, 12:46 PM
Magik Si's Avatar
Magik Si Magik Si is offline
Careful...my canadian made STD did not have a catalytic converter....AT ALL...plus the front pipe that comes out of the exhaust manifold is different than...I don't want to say all others, because I'm not sure...but it is different that "most" other.
The CDN STD had a very unique exhaust...
Jason
www.jasonlorette.50megs.com
90 Civic HB Si - D15B1 + MPFI
Old 12-09-2003, 12:47 PM
Bilson8tor's Avatar
well for one this the STD headers are about half the size of all the others
then also right after the headers theres the cat(its vertical) with all the others theres a pipe then the cat located under the cat(its horizantal)
but after that its basically the same
i can post a scan from the manual when i get back home to show the difference visually
Old 12-09-2003, 01:05 PM
marked001's Avatar
Moderadur
Re: f'ed up STD headers
oh ok..I thought you meant canadian std's were different than us spec...that's typical of all std's/hf's...
SOLD!
Old 12-09-2003, 01:14 PM
91civicDXdude's Avatar
88 & 89 civic STD shares the HF style exhaust manifold and catalytic converter setup. in 90, they switched back over to the DX style with the 4-1 manifold and cat under the car.
Any exhaust setup will bolt right up to it, but for legality, you'll have to add a catalytic converter.
Old 12-09-2003, 01:18 PM
Magik Si's Avatar
To my knowledge all "90" Civic HB's were built in Canada (Allison, Ontario plant).
I wonder why my STD never had a Cat. Conv.? Strange.
Jason
Old 12-09-2003, 01:49 PM
marked001's Avatar
Moderadur
Jason
...they were all 'built' there...but canadian and US specs differ in some aspects...
SOLD!
Old 12-09-2003, 07:34 PM
Bilson8tor's Avatar
wow thanks for the info
99 DX header + test pipe sentoyang '96-'00 Civic 1 10-26-2009 02:34 PM
cali spec headers?? AHHKILLA Eclipse 2000+ 0 04-28-2009 12:03 AM
std headers? CivicWarrior '88 - '91 Civic | CRX | Wagon | Shuttlee 5 02-23-2004 02:50 PM
Si header on my STD hatch blade34609 '88 - '91 Civic | CRX | Wagon | Shuttlee 5 01-06-2004 08:58 PM
Cat no the STD header? blade34609 '88 - '91 Civic | CRX | Wagon | Shuttlee 6 12-25-2003 12:02 PM
