Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 12-09-2003, 12:04 PM
Zeroenna Zeroenna is offline
Cool burnt out light switch
I have a 1989 grand marquis 5.0L and i have replaced the light switch for head lamps once and it keeps "melting" due to some kind of electrical feed back and no one seems to know why it happens..I believe it has something to do with my "idiot light" for fuel is always on and my float works in the gas tank also...Does any one have any dash wiring diagrams for '89 grandmarquis since the chiltons manual i have just doesn't have it..Preciate any responses..
Old 12-17-2003, 05:32 PM
Scooting Scooting is offline
Interesting. Let me know if you find one. I have a 1989 Grand Marquis and the dash/tail lights just stopped working. The fuse is ok. I have not idea what the problem could be. Have you experienced the same situation?
Old 12-17-2003, 05:33 PM
Interesting. Let me know if you find one. I have a 1989 Grand Marquis and the dash/tail lights just stopped working. The fuse is ok. I have no idea what the problem could be. Have you experienced the same situation?
Old 02-02-2004, 07:00 PM
anarkist61's Avatar
anarkist61 anarkist61 is offline
Send a message via AIM to anarkist61 Send a message via MSN to anarkist61
Re: burnt out light switch
I had an 88 Crown Vic and it too burned out the light switch, losing head and tail lights. I attributed it at the time to running hella conversion headlights with 100 watt bulbs in the Hi-Beams. I should have run relays (as I've done on other cars but was in a hurry at the time) and tapped the lights off the battery. Maybe there was more to it then?
"Speed don't kill and I'm the proof"- Motorhead
"Life's a gas"- The Ramones.
The left lane is MINE!!
Old 12-12-2004, 01:01 AM
darkwaterdevil darkwaterdevil is offline
its because the stok wire harnes wires are tii small theres better ones u can buy from napa or other part stores just make shre its soldered on so it doesnt loose current and get hot again
TIP: Fix those doorjam switches // no dome light... Intuit Escort 3 11-21-2009 10:27 PM
Brake Light Switch uspres2020 Escort 5 09-28-2009 12:11 AM
Burnt out lights flintstone168 How-To's and Walk-Through's 0 10-20-2007 02:26 PM
HVAC - burnt out lights KKLumina Lumina 3 04-16-2007 12:55 PM
