Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 12-09-2003, 11:34 AM
mikelebo99 mikelebo99 is offline
Angry White smoke
I noticed that my car is emitting white smoke in the morning or after sitting for some time. Is this burning oil? and is it going to become a larger issue?
Mike
Old 12-09-2003, 01:40 PM
BKVic's Avatar
BKVic BKVic is offline
Blue or purple smoke is oil and black smoke is a extremly rich fuel-air mixture. White smoke is normal unless you happen to have a blown head gasket or seal somewhere that is letting engine coolent into the combustion chamber. Sometimes when youve got an internal coolent leak in an engine you can tell by looking at your oil to see if its a creamy frothy looking mixture, if not and your not loosing coolent I wouldnt worry about it.
BKVic
Old 12-09-2003, 05:12 PM
dafrazi dafrazi is offline
Is the smoke bluish in color or just white? If it is white, it is totally normal. On a cold morning the hot exhaust gas mixes with the cold air and this causes the water vapor in the exhaust to condense and form a white smoke (fog). If it 's bluish in color, you might have a coolant leak that is allowing coolant into the combustion chamber like BKVic detailed. In many cases, this is caused by a blown headgasket. So keep an eye on the coolant level. The car will tell you if the coolant gets low.
Old 12-09-2003, 05:19 PM
klohiq's Avatar
klohiq klohiq is offline
Re: White smoke
It's best to check the coolant levels rather than let the car tell you with it's dummy light and temp gauge.
Old 12-10-2003, 03:03 PM
Re: White smoke
I am going to monitor the coolant level closely.
Thanks
Mike
Old 12-12-2003, 08:10 PM
dsatt12 dsatt12 is offline
The white exhaust will often smell like burning antifreeze if the there is a leak also.
Old 12-14-2003, 05:15 PM
HiLife HiLife is offline
Re: White smoke
Yeah I tend to get a ton of white smoke, but the coolant level is fine and it doesn't give off a sweet smell, so I believe it is normal. Especially since it only happened when it started to get colder.
HL
White Smoke Out The Exhaust aduttonater Sephia 0 03-15-2010 05:29 PM
91 Blazer Blows Smoke 91s10blazen S-10 6 11-25-2009 07:56 PM
White Smoke civic91dx '88 - '91 Civic | CRX | Wagon | Shuttlee 5 07-17-2002 07:29 AM
White smoke mjnaakt Engine, Transmission and Drivetrain 2 06-14-2002 07:55 PM
