Old 07-16-2002, 11:38 AM
civic91dx civic91dx is offline
Send a message via AIM to civic91dx
White Smoke
I have a question about white smoke. Well i lost my lic for 4 month and i havent driven my car for about a month. i had to take my filter off because i got it wet and i was letting it dry. i turn it on because i had to go to the store and the car started to smoke white. what does that means?
thanks
carlos
91 civic sold, i miss it
new car 98 Monte Carlo Z34, dont worry guys i still love honda
http://www.cardomain.com/id/losboricua
Old 07-16-2002, 12:13 PM
DVSNCYNIKL's Avatar
DVSNCYNIKL DVSNCYNIKL is offline
R.I.P. DAD 3/25/11
Send a message via ICQ to DVSNCYNIKL Send a message via AIM to DVSNCYNIKL Send a message via Yahoo to DVSNCYNIKL
Could be condensation since the filter was wet, but doubt that. Since you haven't turned your car on for 4 mos. the oil is burning for some reason.
Why do banks charge you a "non-sufficient funds fee" on money they already know you don't have?
Old 07-16-2002, 12:41 PM
I im going to check that and change oil and spark plugs and everything. if not im think about puttin a d16 of a 98 civic in my car but then i have to deal with converting the dual point injection system to a fuel rail injection system
Old 07-16-2002, 02:38 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
OIL burns blue not white, white is your Antifreeze/coolant, you may have a head gasket leak somewhere and it getting into the combustion chambers.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 07-16-2002, 02:43 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
it may not be anitfreeze. white smoke is just that your car is burning water. could be condensation because you left it so long
try and run it for alittle while then like after a few hundred miles if its still doin it then you probably got a coolant leak. check your coolant to see if its down
Old 07-17-2002, 07:29 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Head gasket was the first thing that came to my mind. As in water coming into the oil circuit and possibly the cylinders. Solution is a new gasket and having the head milled to make sure it is flat. One way to tell if it is shot is to look inside your oil cap - if there is a thick, cream-like emulsion all over it (off white), then you have a lot of water in your oil.
But... drop your oil out and change the filter. Maybe change it again after 200kms or so in case there is condensation in the oil. See what it's like then. Also, remember that if the car has been sitting, there may be condensation in the cat and muffler - that will take a bit to get rid of. That's assuming it's steam, if it is smoke, then there is thin oil, probably with H20 in it.
Hopefully not
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
White Smoke Out The Exhaust aduttonater Sephia 0 03-15-2010 05:29 PM
91 Blazer Blows Smoke 91s10blazen S-10 6 11-25-2009 07:56 PM
tons of white smoke, help!! Tominos Engineering/ Technical 8 09-25-2002 10:36 PM
White smoke mjnaakt Engine, Transmission and Drivetrain 2 06-14-2002 07:55 PM
