Old 12-08-2003, 01:34 PM
EvoVI's Avatar
EvoVI EvoVI is offline
Send a message via ICQ to EvoVI
Have aneone had the same problems with Evo V?
So its Tamiya Evo V WRC, i just started it, and when i was applying the decals on the sits i found out that after i apply Micro Sol the edjes of the decal do not stick to the surface as usual after Micro Sol but start to "roll" (don't know how to explain in other words) So is it a problem of old Tamiya decals or a problem of my skills or what? It was OK with Evo VII and 2001GB and 2002 Imprezas.
Old 12-08-2003, 07:23 PM
RallyRaider's Avatar
Zomby Woof
Tamiya Evo VII doesn't have CF seat back decals does it?
Perhaps you left the decals in the water too long and the adhesive dissolved away? How did you go fixing it? Some PVA glue can be used to replace the decals adhesive if it loses it's 'stick'.
Old 12-08-2003, 07:29 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Re: Have aneone had the same problems with Evo V?
That's my guess. They say to leave decals in water for 30 seconds, but usually I leave them in for half that or so, and let them sit on the paper towel (still wet, I don't dry them when I put them on the towel) until I can scoot the decal around ont the backing with my finger or toothpick.
Old 12-08-2003, 08:29 PM
clem24 clem24 is offline
Hey, I get that problem too! I think a coat of clear may be the only way to solve it (after its too late). Otherwise, I just inspect my models here and there, and if I discover one peeling, then I just put some microsol on it.
clem..
Old 12-08-2003, 09:20 PM
David_ David_ is offline
with all my tamiya models, all the decals just used water... some fell off, but i reapplied them with minimal fuss...
i duno why you'd need microsol, but i also heard that tamiya decals are too fragile for microsol, and they'll just melt away into nothingness, on certain occasions.
Old 12-08-2003, 09:33 PM
Kasso's Avatar
Kasso Kasso is offline
Send a message via AIM to Kasso Send a message via MSN to Kasso Send a message via Yahoo to Kasso
many people have advised me to use micro set instead of micro sol. so, im gonna buy some on my next trip to the LHS.
1995 Acura Integra Special Edition (something real special about a 5000 rpm changeover... )
Old 12-09-2003, 05:33 AM
EvoVI's Avatar
2 RallyRaider: Yes, Evo VII dorst't have kevlar decals (who knows it better than you ) but i'am worried about all the decals, it isn't dramatic on the interior parts, but what if it happens with exterior decals, anyway i'll try to keep them in water not so long.
PS I always use MICROSOl, it makes decals look "painted" and removes "silvering", till tomorrow it was always OK.
PPS RallyRaider I wish to have your skills
Old 12-09-2003, 05:37 AM
EvoVI's Avatar
I din't usу this method, i just put some MiroSet, whait a little. then press the decal with wet cloth and remove the bubbles and irregularities with Q-tip. Then i apply MicroSol and when it is dry i clear coat the part.
Old 12-09-2003, 05:51 AM
Zomby Woof
Thanks for the compliment EvoVI, it sounds like you have heaps of skills too! You had a problem with the decals and solved it, modeling is often an exercise in damage control afterall!
Are you using Microsol, the one with the red writing? I find that is too strong for recent Tamiya decals, and needs to be diluted or just stick with Microset. It does work well to give the painted on look like you say and is indespensable in making decals conform to complex shapes. You probably needen't worry about the rest of the decals doing the same thing, just follow Willmo's advice, take it easy with the Microsol and you should have no more problems.
I hope when you finish you can take some photos and show us your Evo V (and other rallycars as well)
Old 12-09-2003, 12:34 PM
EvoVI's Avatar
Thanks friends, i will fight and i will certanly win!!!
PS Yeah i've got to take my friend's digital camera, or finally buy one for me and show the world my babies.
Old 12-09-2003, 01:30 PM
Valentino Valentino is offline
Hi.I built EVO V WRC kit a while ago. I didn't use any decal solution and the decals worked really well. I think microsol is too strong for the decals.
La Vecchia Signora & BMW maniac.
Old 12-09-2003, 04:38 PM
EvoVI's Avatar
Yeap, the problem is that i am kinda "microsol addict" i use it everywhere, it probably comes from the old Soviet times when we had only poor aircraft kits from Poland and Chech Republic, and the decals were terrible, it was imposible to attach them properly, they were silvering teribly, and you could easily lost them when cleaning your model, ans you understand that in USSR we didn't have access to decals solutions e.t.c. This kind of hobby wasn't very developed in USSR, we built planes at school, but that were scratch-built models. So thats the short story
Old 12-09-2003, 06:45 PM
I'd have to agree about the microsol on Tamiya models: they are pretty strong for the decals. I use it only on curved areas or when they start peeling. I find warm water, a moist paper towel, and lots of patience are best for Tamiya decals on flat areas. If you try applying microsol to a flat area, then the decal wrinkles up and dries that way without flattening.
You can also try Gunze Mr. Mark Softer. That stuff is no where near as potent as Microsol. I used to have that stuff, but ended up spilling it all (oops!). But the bottle comes with a brush applicator, so it makes for a very good bottle for microsol!
As for microset, it smells strangely like diluted vinegar.. Does anyone know whats in there? And would diluted vinegar have the same effect??
Crazy Modeler CF decal - had the same problem? klutz_100 Car Modeling 6 11-22-2009 07:58 PM
Does 99LHS have the same Headlight with concorde(04)? newcomer LHS 3 06-22-2005 10:54 PM
91 riviera owners seem to all have the same problem Cheech43 Riviera 1 03-04-2005 03:07 PM
Anyone had the same problem?? 96HondaCivic Sienna 2 03-07-2004 12:36 PM
