Old 12-15-2001, 09:13 PM
13secondcivic's Avatar
13secondcivic 13secondcivic is offline
91 SiR guage cluster install Q....anyone done one?
Hey guys,
I' about This :alien2: close to getting a SiR guage cluster.....someone mentioned to me about needing an ESS, electronic speed sensor? and it could be gotten off of a Del Sol VTEC motor. Do you need it for this guage cluster? and where would I find it? where does it go? etc....
thanks!
PRI-RACING. com
-2000 Honda Odyssey
PRI cold air intake
Thermal based exhaust
RC bored throttle body
Wings West body kit
SPEEDY ATIX5 18" rims
225/45-ZR18 Contisports
Tanabe 2.25 inch drop springs
CDT Audio HD speakers
Coming soon:
-Nitrous express 75 hp N2O kit!
-RT free flow cat
Old 12-15-2001, 09:44 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: 91 SiR guage cluster install Q....anyone done one?
you will need one for the SiR cluster, all the VTEC engines use vechile speed as one of the conditions for engaging VTEC, so they use a speed sensor and an electronic Speedo. (which makes them VERY acurate.)
One off a del sol sounds good, it goes in the same place the normal cable drive is located, and you should be able to just swap it for your one with no work. (I think thats why you need the del sol one, so the threads etc match.)
Old 12-15-2001, 10:44 PM
Thanks bud!
PRI-RACING. com
-2000 Honda Odyssey
PRI cold air intake
Wings West body kit
Coming soon:
-RT free flow cat
torsion bar swap, anyone done one markhs2 C/K 0 05-09-2004 05:30 PM
SiR cluster, Installed but 1 problem EF_LSVtec '88 - '91 Civic | CRX | Wagon | Shuttlee 14 10-18-2002 02:01 PM
SiR guage cluster problem 13secondcivic '71-'87 Civic | CRX 1 02-16-2002 12:52 PM
Has anyone installed SiR guages diegoaccord '71-'87 Civic | CRX 1 02-16-2002 06:51 AM
Q on B16 install...whoever has done one? 13secondcivic Engineering/ Technical 7 12-28-2001 08:43 AM
