Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 12-05-2003, 01:52 AM
DevoutWankelist's Avatar
DevoutWankelist DevoutWankelist is offline
Send a message via ICQ to DevoutWankelist Send a message via AIM to DevoutWankelist
couple of questions
okay,
"There are several ways to actuate 6-ports electronically. And its very cheap. All you need is a pressure source (air pump, etc), a solenoid, and a signal thats rpm activated."
- J-Rat
I woud appreciate it if you could give some detailed instructions on this, and maybe some more general information on its application, also I was getting ready to set up an exhaust system and seeing as I cant afford all of the components of a commercial one and the local law enforcement in my area would grin if they saw no emissions controls before they even thought of it maybe being a ticketable offense I was going to manufacture my own with just straight pipes. I heard that 2 inches was best for an rx7, but I dont remember where and cant find the website again so I wanted to see what everyone else thought first.
Also does anyone know the specific volume of gas that is in ignited during combustion?
Old 12-05-2003, 11:35 AM
J-Rat's Avatar
J-Rat J-Rat is offline
Send a message via AIM to J-Rat Send a message via MSN to J-Rat
Are you planning on retaining the ACV? Or is all of the system going? That would determine they type of system we would need to set up.
Jarrett
1988 10th AE Edition TII
More mods then you have.
Old 12-05-2003, 08:51 PM
Re: couple of questions
Yeah, im removing the whole system
Old 12-08-2003, 02:54 PM
J-Rat's Avatar
Hmmm..that complicates things a wee bit. There are several ways to accomplish this, but without a source of pressure (ie the air pump), it pretty much becomes impossible. Unless you want to rig like a GM air pump, and a switch (RPM activated, of course).
Old 12-08-2003, 10:47 PM
okay so it would probably be best if i left the air pump connected?
Old 12-09-2003, 02:16 PM
J-Rat's Avatar
Or you going to have to either remove the 6p sleeves or wire them open. Either option isnt necessarily what I would consider to be conducive to good low end characteristics.
Old 12-09-2003, 10:59 PM
Steel's Avatar
Steel Steel is offline
Ok..my turn.
How difficult would it be to make an electric motor drivin 6 port actaution syatem, which was RPM dependat, i.e. it *starts* opening the 6 ports at 3800 and finishes at 4500 (about, iirc) like it's supposed to?
Old 12-10-2003, 12:24 AM
Entreri33's Avatar
Entreri33 Entreri33 is offline
Send a message via ICQ to Entreri33
OK having had non working actuators I think the best solutionis a pair of zip ties and just wiring the two bastards open. You'll loose a little low end torque at low RPM but what the hell just give it some more gas.
Had 2 cars totalled in 2 years.... searching for a new toy. Maybe another RX7(w/20b) or a 280Z(w/rb26dett)
I had...
87 RX7 sport (drove it for years)
01 Firebird
Need a new project car.
the 5th column will be the death of the american dream.
found a couple problems...now i have a couple questions 97GSTspyder Off-Topic 2 07-02-2005 10:33 AM
New Owner, couple questions OneBad4 Millenia/Xedos 9 3 04-17-2003 12:10 AM
My new model, couple questions. kicker1_solo Car Modeling 11 06-13-2002 02:48 AM
Got a turbo...and a couple questions with it essex Forced Induction 6 04-29-2002 12:13 PM
B18 motor ?? couple questions 90civicrider '71-'87 Civic | CRX 1 01-17-2002 05:30 PM
