Go Back   Automotive Forums Car Chat > Honda > Integra
Old 12-05-2003, 12:41 AM
WhiteTeg WhiteTeg is offline
ok...
ok....got a couple stuff to talk about. i purchased my teg wit just exhaust on it already. But i seriously have no idea if its a full exhaust or not.? how can i check?
and anyone that knows about cd decks... my dumb ass brotha turned the volume up all the way and it turned off and wont come back on. I checked the fuse but theres nothing wrong wit it. What could be wrong?
does anyone know where i can find 98-01 tail lights? Im sick of my altezzas.
anyone know how hard it is to install the power antenna. mines fuckin broke. I know over 10 people that have tegs and like 3/4's of their antennas are broken or were replaced already
Old 12-05-2003, 02:23 AM
91LSspecial 91LSspecial is offline
Re: ok...
my cd deck does the same thing when i turn it up too high, but i i have fuses byhind my deck spiced in some wires, and i repaced those. as far as the pipe, just get under there, you shoudl be able to tell by the contrast or the pipes, ebay=tail lights
Old 12-05-2003, 03:22 AM
tran_nsx's Avatar
tran_nsx tran_nsx is offline
Re: ok...
nice looking teg
with the exhaust, just look underneath the car, if it goes all the way to the catalytic converter than its a full cat-back system.
for the deck, just in case check both fuses. one fuse in the deck and the other where all the other fuses are located. mine is on the lower driver side panel, not sure on the 3rd gen, but it should be similar.
for the tail lights just go to ebay, they got some good deals.
for the power antenna, it shouldn't be too hard. i install a new one on my 2nd gen and it wasn't all that difficult. the only issue was that i had to remove several panels in the trunk, but that was about it. u can also get an antenna off ebay, i did
also i just want to say, now we got two whiteteg here on the forum
Old 12-05-2003, 04:01 AM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
Re: Re: ok...
Originally Posted by tran_nsx
nice looking teg
uhm...the stock piping goes all the way back to the cat too...so hrmmm...that won't really work now will it?
ur stock exaust should be around 2 in around, so if its bigger, then its after-market.
(had to do it tran)
as for the rest of the stuff...tran is correct...
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 12-05-2003, 12:38 PM
aight
thanks for the replys.
when i looked behind my stereo i only see one fuse. its on a yellow wire that says battery. but on my old stereo there was actually a fuse connected to the deck so i have no idea why this one doesnt have one.
and as for the exhaust i still have no clue.
Old 12-05-2003, 05:29 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Re: ok...
I was thinking the same thing
Try looking here for the tails also www.thepartstrader.com And for the antenna it is simple to replace you can just replace the mast or replace the whole thing either way it is fairly easy. Just be careful with the locking nut on the mast, you can take a towel and wrap that around it and use pliars if you don't have the wrench.
Old 12-05-2003, 08:40 PM
shaunthebadass shaunthebadass is offline
Send a message via AIM to shaunthebadass
Re: ok...
check on the driver side by your feet under the dash in the fuse box. on the cover it tells you which fuse goes to which. check your accesory fuse. it is possible when your genius friend decided to try to blow ur shit, the cd player started pulling too much current and as a safety device the fuse blows because if ur player was to get that much power it could hurt it. as for the fuse behind your cd player on the yellow wire, it is the same as an after market, it is linked to the power wire, same as after market......only difference is that you can see the other side of the wire as it comes from the fuse when you couldnt see it in your othewr one because it was hidden inside the player itself.....hope this was helpful.
Old 12-06-2003, 09:39 AM
tran_nsx's Avatar
Re: Re: Re: ok...
(had to do it tran)
i hate u racer
Old 12-09-2003, 11:31 AM
i
i checked all the fuses and nothing worked
Old 12-09-2003, 11:32 AM
gdgd
Old 12-09-2003, 12:02 PM
tran_nsx's Avatar
Re: gdgd
my next suggestion would be to get another deck from a friend or if u have one and hook that up. if it turns on than i guess your original deck is fu*ked up. u can either get a new deck or take it to the shop and have it repaired.
another method is to get one of those electrical probes that lights up when it touch eletrical currrents. i forgot what that probe is call, but stick it in the connectors that gives the deck power (the red and blue), once of course u pull the connector out of your deck. this lets u know if you're getting power at all.
'01 no start, batt ok,starter ok,batt term ok elmono Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 12-09-2009 11:07 PM
OK.. OK... OK... Getting there, questions.... Earlsfat Engine and Transmission 5 08-03-2007 06:39 PM
Ok Ok Ok, Here Is The Pic Of The Wing Team PHATBOYZ '88 - '91 Civic | CRX | Wagon | Shuttlee 22 09-30-2005 06:15 PM
Diggind up old Threads - OK or Not OK? Poll Guido Car Modeling 22 03-17-2003 09:02 AM
