Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 12-08-2009, 07:20 PM
elmono elmono is offline
'01 no start, batt ok,starter ok,batt term ok
2001 Maxima with a no start problem. Have checked out battery, starter is giving it all it can, battery terminals cleaned, positive one replaced. Car turns/rolls over, but will not fire up. Can smell fuel when trying to fire up. Where to start, please?
Old 12-09-2009, 12:13 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: '01 no start, batt ok,starter ok,batt term ok
Easy test for MAF is to disconnect its wire/plug (shorted MAF can kill engine)
Next check for spark: find spare plug, pull one coil, insert plug, ground it, start and see if spark present...
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 12-09-2009, 12:22 PM
Hi, and thanks for the note. I am familiar with MAP, but not MAF. Could you please explain what it is? Thanks.
Old 12-09-2009, 11:07 PM
Mass Air Flow meter, intake air flow measurement. The blk tingie after air filter... Normally it cant kill engine but if its shorting, then may do that... Unplug, engine will start and run in safe Mode = 2.2k rpm ceiling.
Check my web site p9, link below; functions are the same as in older models.
