Go Back   Automotive Forums .com Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 12-04-2003, 11:17 AM   #1
j. brinkley
steering squeak.. TSB
Has anyone had this problem? TSB applies to MY01-02
I'd hate to take the column assembly apart only to find that I need some part from the dealer.
I only have the notice, not the whole TSB
thanks for any help
j. brinkley is offline   Reply With Quote
Old 02-21-2004, 03:56 PM   #2
Buchanan6
Steering squeak
J.-
I have a 93 Pathy and I had the same problem...drove me nuts! I was too lazy to pull the steering column off for the longest time. Soon I was going out of my mind and had to bite the bullet. Here's how I fixed it:
You need a long #1 phillips and a can of WD-40. On your steering column cover there are about 3 screws on each side holding it together. Unscrew them. The column cover should come right off. This gives you access to the backside of the steering wheel. There is a narrow gap/space where the actual steering wheel meets the column. Give the WD a little squirt in that gap. Problem solved.
Buchanan6 is offline   Reply With Quote
Old 03-08-2004, 07:25 AM   #3
j. brinkley
Re: steering squeak.. TSB
thanks for the help, but it's the spiral cable (airbag)
the part is on order, I just hate taking it to the dealer.
In case anyone else hears rubbing/squeak when turning the wheel, usually when cold. It's probably that cable.
replacement isn't a DIY, at least for me anyway- even with the service manual
BTW MY PATHFINDER IS FOR SALE- 2002
Windshield wipers and a TSB 2001 GM MrRealtor Grand Marquis 2 09-30-2010 09:52 PM
Steering squeaking and other problems david-b Brakes and Suspension 1 08-18-2009 12:33 AM
Steering Wheel Repair JDatx512 Tacoma 0 03-30-2009 01:55 PM
2002 Steering Squeaking BigFig15 Grand Marquis 12 07-22-2007 03:30 PM
Steering squeaks ibabouniaj Taurus | Taurus Wagon 1 06-18-2004 07:57 AM
