Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Brakes and Suspension
Old 10-29-2008, 09:13 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Thumbs down Steering squeaking and other problems
Good times today...
Firstly, when I turn the wheel any direction, it squeaks, like almost metal on metal squeaking. Almost sounds like something needs WD-40. I don't see anything rubbing, and didn't have someone else around to turn the wheel while I was in the engine bay. It does it while moving or not. Any ideas? And I don't have PS, so it's not leaking unless something got inside the reservoir, but it doesn't sound like that.
The steering itself has been kinda sucky. When I'm driving and go to shift, the steering wheel will shake back and forth very quickly a couple times. It's when I let go of the clutch all the way. Any ideas there? I have a feeling that this problem and the one above may be related.
Also getting a popping now from the passenger wheel well. Guessing a joint somewhere. I've had the control arms replaced and resealed, and the inner and outer tie rods replaced since I bought the car, so I don't know what else that can be.
Alignment sucks BTW... just thought I should throw that in but it's been like that forever.
I'm going to pick the car up this weekend and see what I can find. Then I'll probably take a day off and take the car in. Anyone have problems like the above?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 08-17-2009, 11:33 PM
bravo44mag bravo44mag is offline
Re: Steering squeaking and other problems
i have the same problem with the squeak when i turn my wheels and go over bumps even if im at a dead stop but i found out that its my strut and when it rains the squeak goes away so i guess some how the water lubes it and reduces the friction but the strut still holds up good so i don't know how to fix the squeak permanently. so if someone could give me some tips that wood be great!
