Go Back   Automotive Forums Car Chat > Renault > General Discussion
Old 12-15-2001, 12:51 PM
moodyblues100 moodyblues100 is offline
Unhappy Starter on Renault Encore
I have a 1984 Renault Encore that had the starter replaced. After the starter was put in grinding noise has shown up when the key is initially turned. The grinding lasts a second or so and then the car starts and runs fine with no unusual noises
Several starters were put in to try to eliminate the noise but it hasn't helped. The garage speculates that it may be the flywheel but will not gaurentee it. They say it's a 6 - 7 hour job to get to the flywheel. I hate to put that much money into this old car(although if there was some assurance this would correct the problem I would consider it), but aside from the momentary noise the car runs fine.
Will there be some warning before the car completely dies? If the car has started and the noise no longer existst am I still causing damage?
Any input or thoughts would be appreciated.
Thanks, Jack
Old 01-09-2002, 07:24 AM
Jimster's Avatar
Jimster Jimster is offline
Here for the pussy, man.
Send a message via ICQ to Jimster Send a message via AIM to Jimster Send a message via Yahoo to Jimster
Encore=11???
Check out my Pride and joy in AF- and discuss your favourite Alfa Romeo
2007 Audi A4 3.0 TDI Le Mans
Old 02-27-2007, 01:52 AM
RODALCO RODALCO is offline
Re: Starter on Renault Encore
Hi Jack, seeing this post is 6 years old and you may have not even got your Renault anymore.
It is quite possible that a couple of cogs have worn very badly, or broken of from the ring gear hence the short noise at first when starting.
4 Cylinder car engines very often stop in 4 the same positions so certain cogs will have a lot more wear when the starter forces the pinion in mesh to turn over the engine.
Only remedie in your case is to take the flywheel off and have the ring gear replaced.
RF. Meters, Clocks and Trains are great.
Cars give you freedom and stress.
Raymond ,Titirangi, Auckland, New Zealand
Renault Laguna non-starter tiggywig1959 Laguna/Laguna II 0 02-28-2010 09:41 AM
Smokey starter ... reanult kangoo.. 007daniels Kangoo/Kangoo II 0 04-02-2009 02:58 AM
no start: starter or battery? sbbob Grand Prix 15 03-30-2009 02:19 AM
E 150 Starter problem NIck86 Econoline 3 03-12-2009 07:38 AM
