Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 12-02-2003, 04:58 PM
anicemonkey anicemonkey is offline
muffler question
I have a crack around the exhaust pipe that goes into the long round muffler. I assume it is the muffler. It is after the cat, and under the car NOT by the bumper. I have tried using muffler weld but it has not helped. Since the whole exhaust is all one piece I guess I would just cut the muffler out and put in a new one. Have anyone done this? What parts do I need? What size exhaust pipe is on the 99 SL2? Any help would be great!!
Thanks,
Brad
Old 12-02-2003, 09:11 PM
31rx7 31rx7 is offline
Re: muffler question
Interestingly, I have the same problem. This "muffler" is really the resonator. It tends to develop leaks around the rear seam of the resonator.
I was going to replace it with another one, but hate to shell out the money for a new Saturn piece.
On my 1998 SL2, the outlet pipe is 1.75 OD. I have not found an aftermarket replacemet yet. Muffler weld doesn't seem to hold.
Suggestions welcome.
Old 12-03-2003, 04:47 PM
31rx7,
Thanks for the reply. Do you know how to properly jack up the car with a 3 1/2 ton floor jack? I am not sure where to place it to lift the front.
Thanks,
Brad
Old 12-03-2003, 05:33 PM
When I need to raise the front of the car and put it on jack stands, I
- Jack it up on one side part of the way
- Put some 2x8 wood boards under the tire (the boards are bolted together to make a single piece)
- Let the jack down
- Go to the other side and jack it up to the desired height
- Set the jack stand on this side
- Go back to the first side and jack it up the rest of the way and set the jack stand.
You have to be careful to ensure the floor jack rolls when jacking up from the side, or it will force the car off the first jack stand.
There must be a better way to raise the entire front end at once, but I do not know what it is.
Old 12-03-2003, 07:18 PM
Thanks for the reply on jacking. Where exactly under the car do you place the head of the jack? On the side rail? Somewhere else?? I am not sure and I do not want to do damage. Thanks for all the help
Brad
Old 12-03-2003, 08:03 PM
I jack it up where the subframe mounts to the unibody.
Old 12-07-2003, 05:38 PM
XTCaTuRn XTCaTuRn is offline
Send a message via AIM to XTCaTuRn
Hey guys, if you're looking for an aftermarket performance exhaust system (which includes a new resonator with no leaks lol) then check out www.saturnmotorsports.com . this site is great for powerful upgrades. There's an HKS cat back system that's around $475 but i have it on my 1995 sl2 and its WONDERFUL. i disconnected the axle back system and ran a straight pipe out the side of my car and it sounds AMAZING. this system is a whopping 2" mandrel bent exhaust system that frees up a great deal of low end torque. IM me if u have questions
Old 01-08-2005, 09:48 PM
mythconcepts mythconcepts is offline
Send a message via AIM to mythconcepts
the sway bar can with stand the weight long enough to get jacks under the engine cradle or sides. just make sure you put the jack in the middle!!
Remus is the way to go! or just get it bent custom thats what I did
Old 01-09-2005, 02:01 PM
carguy83 carguy83 is offline
Send a message via AIM to carguy83
ok
none of you are allowed to touch your vehicles.
there are jack points behind each front tire and in front of each rear tire. DO NOT PUT IT ON THE SWAY BAR. thats just a bad idea waiting to go wrong. you can goto autozone and customize your own exhaust with some 2.5" piping and just get a muffler for it. or get a custom mandrel bent... be prepared for tickets if you go big
1995 Gold Saturn SL2 -- RIP May 05
1991 Blue Subaru Legacy Wagon -- RIP Aug 05
1995 White Mazda 626 DX -- RIP Feb 07
1991 Black Volkswagen Jetta Carat -- Current
Old 01-09-2005, 06:43 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: Re: muffler question
don't put it there, go with the oil pan, radiator, or fuel tank....
ok don't
Old 01-10-2005, 12:05 AM
sierrap615... what a sense of humor...
but seriously dont put it on any of those things
exhaust question 89corollajoke Corolla/Matrix/Voltz 2 07-08-2009 11:22 AM
Muffler Question? Dahmin8 Accord/TSX/Accord Hybrid 8 03-16-2002 09:49 AM
