Old 12-02-2003, 11:39 AM
Eskareon Eskareon is offline
Send a message via AIM to Eskareon
Question Changing the master cylinder
Symptoms: Periodically, the brakes will become very soft and the pedal will nearly go to the floor before I can feel braking power. When this happens, I let the pedal come back up and then give it a quick thrust and then it'll stiffen up. I've found that it more than often goes soft when I brake very casually / slowly. However, if I always begin braking by giving it a quick thrust, it seems to be fine.
Possible Solution: After taking it to a couple places, the mechanics said they believed the valve in the master cylinder is cracked and thus not holding when I brake slowly. So, I purchased a master cylinder.
How would I go about changing it out? I've been told it's not a complicated procedure and if done well I might not even have to bleed the brakes afterward. Will I require any special tools, etc.?
How much if I need to change the Master Cylinder? Ken_OY Camry/Camry Hybrid/Vista 2 09-29-2007 10:02 PM
How to remove the master cylinder. shadow322 Cavalier Problem Diagnosis 1 02-25-2007 04:26 AM
what is this thing near the master cylinder???? nalgman Blazer 8 07-28-2005 02:04 AM
Bleeding the master cylinder jocaan Suburban 0 07-07-2005 05:50 PM
Air in the master cylinder Sunliner Blazer 4 12-19-2004 12:22 AM
