Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 12-02-2003, 10:00 AM
franklincounty franklincounty is offline
pathfinder cylinder misfire-code 0701
My wifes 1996 pathfinder continues to show the multiple cylinder misfire detected from time to time. The vehicle run great and I've never experienced an engine miss! Has anyone experienced this and what was the cure. Thanks in advance.
Old 12-03-2003, 06:46 AM
lewisnc100 lewisnc100 is offline
Re: pathfinder cylinder misfire-code 0701
Start by checking for an intake air leak, listen while the engine is idling for a leak. When was the last time the plugs were changed, replace them and see how they look if it's been a while and also check the ignition wires and distributor cap. Beyond that here's the list of possible causes:
Improper Spark Plug
Insufficient Compression
Incorrect Fuel Pressure
EGR Valve
Injector circuit open or shorted
Injectors
Intake air leak
Ignition secondary circuit is open or shorted
Lack of fuel
Magnetized flywheel (drive plate)
There is also a TSB (NTB99-015) on your pathfinder for these errors being tripped by a coolant leak at the throttle body. Remove the air intake at the throttle body and check for any coolant inside, if there is you'll need to have the intake collector replaced. Also look for any coolant on the side where the line comes in. This leak happens from a manufacturing defect so if you have it I'd push for it to be covered by Nissan.
Old 12-05-2003, 07:44 AM
Re: Re: pathfinder cylinder misfire-code 0701
Improper Spark Plug
EGR Valve
Injectors
Intake air leak
Lack of fuel
lewisnc100, I appreciate all the info. you sent and I will check for a intake leak and go from there. The plugs are new-but distributor and rotor are original with 115,000 miles on vehicle. I may replace them and see what happens. I can drive the vehicle for 500 miles or so before the code appears. Thanks again, Briant
Multiple cylinder misfire codes Pokee Windstar 6 05-04-2010 09:10 PM
02 Dakota Multiple/ Random Misfire, Cylinders 2,4,5,6 osuyaqui Dakota 3 04-09-2009 08:49 AM
P0305 Cylinder 5 Misfire wmuwop Explorer | Explorer Sport Trac 3 03-31-2009 06:40 AM
Weird #3 cylinder misfire gesellman Trooper | SLX | Bighorn | Wizard 2 03-06-2009 11:31 PM
6 Cylinder Misfire Code Waynehead99 Sonata 3 01-05-2005 04:43 AM
