Old 12-01-2003, 06:32 PM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
weird idling, wavy
sometimes when i'm stopped at a light my engine idling will kind of falter, and it will rise and fall, almost like it wants to sputter and die. its been happening since the radiator went, so when hte car gets hotter it happens. any ideas?
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
Old 12-01-2003, 06:53 PM
gsf1200m gsf1200m is offline
I dont know if this is the same situation you are in, but my car used to do that, and sometimes it would just dies. My mechanic told me to use fuel injector cleaner, and it has never done that since.
Old 12-02-2003, 10:47 AM
CZ-R's Avatar
CZ-R CZ-R is offline
Send a message via AIM to CZ-R
Are you getting any codes? Mine used to idle the same way when I was getting a code 1 (O2 sensor).
Old 12-02-2003, 11:21 AM
JimCRX's Avatar
JimCRX JimCRX is offline
It might possibly be your Idle Air Controller/Mixture. Do you have any problems starting the car? If it is starting up bad you Ignitor might be going wrong. If the car is stock take it to a Diagnostic center and have it checked.
Old 12-02-2003, 03:27 PM
Jay eS Iye's Avatar
Re: weird idling, wavy
no codes, unless the bulb is burned out
I have been having some problems with the starting actually. Sometimes it'll act like there isn't enough juice to start it but if i leave it cranking it will slowly pick up turning speed until its about normal, then i'll stop, try again and it'll start. i had the battery tested and they said its still good. i was told that it could be the Main Relay, but now possibly the ignitor... any other ideas? i don't want to take it in b/c i don't have alot of money ot drop on a test for it
Old 12-02-2003, 08:51 PM
91civcex4dr 91civcex4dr is offline
hey justin the car did that when i had it, i just thought i would let you know that, but it only did it every now and then
Old 12-02-2003, 09:40 PM
Jay eS Iye's Avatar
thanks bro, so its an ongoing thing. was it the starting thing of the idling thing jason?
any more ideas?
Old 02-18-2004, 09:54 PM
Jay eS Iye's Avatar
bring this back from the dead b/c its bothering me again.
i've tried fuel injector cleaner and fuel cleaner, also gone to high octane. at first it stopped but its back again.
Old 02-19-2004, 10:36 PM
rosshatch89 rosshatch89 is offline
Send a message via AIM to rosshatch89
try checking for vaccum leaks mine had a leak right after i rebuilt it and it did that
Old 02-20-2004, 11:50 AM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
try making sure your idle control sensor is hooked up right, I doubt it is that cause it is not throwing any codes, but you never now
KoRnSaQ
Old 02-20-2004, 03:48 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
try changing ur sparkplugs and see if your throttle body is dirty. Our thunderbird would rev when it started for like a minute and then it got so bad that it would rev just to keep itself running (rpms dropping to 200 and then revving to 1200). But once we got new spark plugs and we cleaned the throttle body it was fine.
1991 Honda Civic DX Sedan
Weird Idle After Warm Calebz '71-'87 Civic | CRX 12 06-26-2007 11:48 AM
Weird idle problem.. doug294 '88 - '91 Civic | CRX | Wagon | Shuttlee 2 06-12-2004 09:37 AM
Weird idle mrlucci4051 Engineering/ Technical 3 05-10-2004 09:33 AM
weird idle on my p11 doodledo824 Maintenance 10 11-29-2002 05:40 AM
