Old 12-01-2003, 06:07 PM
cuba3377's Avatar
cuba3377 cuba3377 is offline
Exclamation Neutral safty switch, and a cruise control switch????
Hey guys, i have a custom 94 integra ls, and i sent the car in to install an alarm, with remote start. i showed up to pick it up, but the guy disabled the cruise control switch on my car. so when i press the clutch, it doesnt disengage cruise control. he said he counldnt find the other switch.
SO........ WHERE EXACTLY IS THE NEUTRAL SAFTY SWITCH ON MY CAR?????
i checked myself, but i only saw one switch, anybody mind walking me threw???
THX >^.^<
Old 12-01-2003, 07:07 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Neutral safty switch, and a cruise control switch????
THX >^.^<
Sounds like the guy was lazy and either cut the wire to the clutch pedal or unplugged the switch. That's all it could be. You should be able to see it next to the pedals.
Old 12-01-2003, 07:30 PM
cuba3377's Avatar
Well, i guess it must be a common mistake or something, because most cars dont come with cruise control and MT.
But regardless, he should be able to have info on how to do it
Old 12-01-2003, 08:57 PM
60hz163.5db's Avatar
60hz163.5db 60hz163.5db is offline
hoo haa i have a 96 integra ls and i had no idea that my cruise would shut off when i hit the clutch but it makes sense now. Truly he was prolly usin compustar or ultrastart cuz DEI doesn't recommend using their products in manual vehicles. Sometimes you have to trade. THe easy way to bypass the any clutch is to test all wires then push the clutch in and test to see which wire change and send it to the proper polarity. This will make DEI's work with manual cars otherwise use the clutch engage wire on r/s that are supposed to be installed on manual vehicles.
"Working in car audio has it's advantages, but it also shows you how much money ppl have to waste."
Old 12-01-2003, 09:27 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
Out of all the Hondas I have owned, my current car is the only manual that didn't have cruise. On the older cars, it was a simple push type of switch mounted right in front of the top of the clutch pedal, and the brake switch was right next to it.
1999-2000 Cruise control switches DRW1000 Windstar 10 10-28-2010 12:52 PM
Cruise control freak out cobraprince 3000GT/Stealth 13 03-23-2009 10:41 AM
1998 Zx2 Cruise Control Problems ddppci ZX2 1 02-17-2009 10:59 AM
Brake Pressure Switch and Cruise Control searcherrr Windstar 3 10-26-2007 01:23 PM
2000 LeSabre Cruise Control Switch sallisonbrown LeSabre 2 05-15-2004 04:18 PM
