| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
what is the Hp and do you thank i can pull the front end up
340
2 600 CFM Carburetors, all reworked to 700 CFM each Wiend Tunnel Ram 202 Head, ported and polished, Roller Rockers, Harland Sharpe, 1.5 ratio 11-1 Compression Ratio 620 Solid Lift Cam Shaft Bored Out 30 Over Forged Crank and Rods ARP Bolts in the motor All balanced and blueprinted Double Roller Timing Chain Air Conditioned Water Pump, High Output8 Quart Oil Pan Hooker Headers Ram Clutch Scatter Shielda 10½Crash Box 4 Speed, 1-23 Spline Transmission Heavy Duty Drive Shaft msd 8 ¾ Rear End, 35 SplineStrange Axils and Spool with 488 Gear & Greene Bearings11" Drums in Rear10" Disks in FrontFuel Cells, 12 gallon RCI Blue Fuel PumpFuel Pump, HolleyHPGI FilterFrame ConnectedMini Tubbed |
Your engine isn't the best at low end torque. What duration cam is that? At .050''.
You are probably overcarbed too. 1400 CFM? On a 340? Does it flog out at low RPMS? You are probably making about 550 HP. What are you doing in the 1320? 11's? |
Re: what is the Hp and do you thank i can pull the front end up
did you get your heads bench flowed? what did they flow? What size are your rear tires?
![]() Beware of this Beast! MOPAR: More Overall Power And Reliability |
