Go Back   Automotive Forums .com Car Chat > Engineering/Technical
Engineering/Technical Ask technical questions about cars. Do you know how a car engine works?
Old 12-01-2003, 08:54 AM   #1
72duster
what is the Hp and do you thank i can pull the front end up
340
2 600 CFM Carburetors, all reworked to 700 CFM each
Wiend Tunnel Ram
202 Head,
ported and polished, Roller Rockers,
Harland Sharpe,
1.5 ratio
11-1 Compression Ratio
620 Solid Lift Cam Shaft
Bored Out 30 Over
Forged Crank and Rods
ARP Bolts in the motor
All balanced and blueprinted
Double Roller Timing Chain
Air Conditioned Water Pump,
High Output8 Quart Oil Pan
Hooker Headers
Ram Clutch
Scatter Shielda
10½Crash Box 4 Speed, 1-23 Spline Transmission
Heavy Duty Drive Shaft
msd
8 ¾ Rear End, 35 SplineStrange Axils and Spool with 488 Gear & Greene Bearings 11" Drums in Rear 10" Disks in Front Fuel Cells, 12 gallon RCI Blue Fuel Pump Fuel Pump, Holley HPGI Filter Frame Connected Mini Tubbed
72duster is offline   Reply With Quote
02 Town and Country Lmt, FWD - Clunking from front end and power door problems confused81 Caravan | Voyager 12 08-06-2010 11:19 PM
Creaking Noise At Front-End el ratfink Pacifica 2 12-05-2009 12:57 PM
Front end noise Bob Moore Dakota 5 07-25-2009 05:40 PM
Front End Metallic Clunking amesjm0431 Grand Prix 2 06-17-2009 10:17 PM
what is the Hp and do you thank i can pull the front end up 72duster Engineering/Technical 2 01-02-2004 07:15 PM
