Go Back   Automotive Forums Car Chat > Oldsmobile > General Discussion
Old 11-29-2003, 04:20 PM
tonup59 tonup59 is offline
Question intake manifold
Hi,
I am trying to install a new Edelbrock 7111 intake manifold on my Olds 350 engine. With the manifold came 2 cast iron blocks. You have to fit these in the to center ports, But they won't fit. Is this normal, Do you have to machine them? I bought intake gaskets from Mondello which will block off automatically those 2 center holes. Do I need to fit those iron blocks????
Thanks
Anton
The Netherlands
Old 03-20-2004, 11:30 PM
RocketPowerParts RocketPowerParts is offline
Looks as if you posted this a while ago. Anyway that is an awesome Intake with the correct heads and Carb. Back to the question - It is best not to install those Blanks, they do need to be machined to be put in and afterward they with create a turbulance in the Head. What Year is the engine? What Casting # is the Heads? What Carb are you using? And what Cam is in there? With the proper combination that engine will be pulling you into your seat Hard!
99 Windstar 3.8L Replacing Intake Manifold Gaskets dariem Windstar 8 03-21-2015 05:22 PM
Intake Manifold Gasket End Seals bjaymo3 Grand Prix 5 07-30-2010 08:29 AM
Replace Intake Manifold Gasket Stammtra Cougar 4 07-20-2010 12:13 AM
2002 2.7L Intake manifolds ksparticuspa Intrepid 1 07-02-2010 02:25 AM
Aftermarket intake manifold vs. Ported intake manifold Ziggymidget5 Engineering/ Technical 6 06-26-2004 02:27 AM
