Old 11-29-2003, 05:47 AM
beginner beginner is offline
Which red for Enzo??
I'm confused
In the assembly guide of the Tamiya ferrari enzo it says to spray paint the body with Tamiya ts-8, Italian red.
But if I wan't to airbrush it, which colour should I use then?
The assembly guide also says to get x-7 red, but it doesn't say Italian red. Is it the same color?
Could someone help me out?
Old 11-29-2003, 06:20 AM
Zcaithaca's Avatar
Zcaithaca Zcaithaca is offline
fershizzle
Send a message via AIM to Zcaithaca
what you could do is drain the paint from the can and use it for your airbrush... there is a tutorial here
Zach
Old 11-29-2003, 04:44 PM
Re: Which red for Enzo??
Thanks but I can't get hold of the spraypaint so that won't help me...
Doe's anyone know the answer to my question?
Old 11-29-2003, 04:57 PM
Zcaithaca's Avatar
fershizzle
Re: Re: Which red for Enzo??
o srry i thot u had it.... for your other ? i have found that it not not exactly the same but is very very close.... i cant tell the diff. from a far and barely from close up... just my thoughts
Zach
Old 11-29-2003, 05:39 PM
360spider's Avatar
X-7 is slightly brighter than TS8, but it will look good on Enzo.
http://www.cobracolors.com sells authentic Ferrari rosso corsa and rosso scuderia used on real Enzo's, you may check them. Their paints are wonderful and ready for airbrush (premixed).
Alex
ItalianHorses.net
Old 11-30-2003, 04:46 AM
Thanks! Unfortunately their homepage doesn't work..
I'm guessing that you have been on their homepage so I thought I would ask if their paints are expensive compared to Tamiyas paints?
Old 11-30-2003, 04:56 AM
RallyRaider's Avatar
Zomby Woof
Yeah, the Cobra Colors site appears to have gone under. Even when they were up and running they wouldn't ship outside the USA
As Zcaithaca said X-7 Red is a reasonable match for TS-8 Italian Red. Although there are plenty of other Italian/Ferrari Reds by other companies out there that would do just as well.
Old 11-30-2003, 04:59 AM
Is there some kind of colorchart with different ferrari colors, by other "companies", that I could look at? Thanks!
Old 11-30-2003, 09:29 AM
Bangai-o's Avatar
Bangai-o Bangai-o is offline
Go into your local car shop, they'll have 100s of different reds and pick the one you think looks closest to Ferrari red. Most shops do a colour match if you're that desperate so take a pic of the enzo with you.
Ferrari 250 GTO Progress. Porsche 911 GT3 Complete.
Old 12-01-2003, 04:42 AM
primera man's Avatar
"P-Man"
Do it is TS-8 then paint the whole inside of the body black.
This will help to darken the red up and give's it a very nice looking red.
This is what i done with mine and was very pleased how it turned out.
View All My Models Here.
Old 12-02-2003, 03:45 AM
bvia's Avatar
bvia bvia is offline
Alex
Alex,
Leon Tuft closed CobraColors about 2 years ago. Mike Kookaba took over the business, selling pre-thinned PPG paints, but the lack of interest has also forced Mike to close KoobaColors as well...
hth,
Bill
Old 12-02-2003, 10:27 AM
Martbee Martbee is offline
Well, if you use X8 without having another car shot with TS8 near, you won't tell the difference but yes, it's slightly lighter. So mist the X8 with X1 and you be OK. In which concentration... I don't know but a very light darkering should be neccessary... maybe 5 drops in the whole acrylics jar could be enough. Maybe I'll try this but no today my good friend (meaning that it won't be this month either)... I'm on the 67 Corvette I'm supposed to finish for next year "PRE 70 contest". EWwwwwwh, Testor paint on that babe. What a mess ! But result is "$"$/%" good.
Old 12-02-2003, 11:30 AM
Thanks! I'll try it out on some other peace of plastic first, when I get the paints.
Old 12-02-2003, 02:11 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
The difference between X-7 and TS-8 is hardly worth the effort of trying to darken the X-7 -unless you have other cars painted TS-8 that you will display next to you Enzo. If you paint the car with X-7, it will be a terrific looking red. If you paint the car with TS-8, it will be a terrific looking red. If you paint the car with Acryl Guards Red, it will be a terrific looking red. Unless you have an actual Ferrari painted in Rosso Corsa to place your model on, trying to exactly match the perfect Ferrari red is an excercise in madness.
Two reasons to never listen to an 'expert' opinion about why this red is wrong, and another is right in modeling:
1. Scale Color- A full size car has much more surface area, and collects (and reflects) more light than a 1/24 scale model. Therefore, a model painted with the absolute perfect match color of the full size car will look a bit too dark. To my knowledge, no one has yet devised an objective formula to correct for this. So, by definition, right is a little bit off.
2. Pictures Lie. Period. It is impossible to use a photograph as an accurate color reference. Inconsistency in film, processing techniques, lighting of subject, lighting of photograph, etc will guarantee that the red on a picture of a Ferrari is not the same as the red on a Ferrari.
The only right is what looks right to you. So, paint it with the X-7 (or the TS-8, if you can find), and you'll probably be happy with the results.
Old 12-02-2003, 03:00 PM
Now there's an answer I like. I have no experince in paintmixing and I wouldn't wan't to get into that right now. I just wan't to make my first 1/24 car without any "custom" paintmixes, nice and simple. I might try it out after I have gotten some experince in building models. I think it's better if I, for starters, learn how to use an airbrush.
But thanks everyone for your advice anyway!
Which color for my enzo? KaverL Car Modeling 24 03-14-2006 02:05 AM
COMPLETE: 1/24 Red Hot ENZo takisa Completed Projects / Gallery 3 09-03-2005 11:20 PM
In Progress: candy apple red Revell Enzo Doug E Fresh WIP - Street 25 01-15-2004 06:36 PM
Which paint for a yellow Enzo ? xim-crow Car Modeling 10 07-26-2003 09:43 AM
Ferrari 288 GTO. In RED! Yes Enzo...RED! ZoomZoomMX-5 WIP - Street 2 09-13-2002 10:49 PM
