Old 11-28-2003, 12:28 PM
HondaIntegraXSI HondaIntegraXSI is offline
Send a message via AIM to HondaIntegraXSI
automatic LS/v-tec questions
I am wanting to buy myself a US spec '90 Integra LS, but it is an automatic.. I have to use the JDM PW0 or PR3 pre-obd ecu's w/ v-tec for an automatic transmission. My hope has ran out for finding one of the ultra-rare ECU's and I was curious if an apex unit could control all then v-tec functions the ECU would normally take care of, like the V-tec crossover, the knock sensor, ect.. I will be doing the swap myself, so would the Apex unit be easy to install?? If this unit will control it, then what Apex unit should I look at?? Any help would be greatly appriciated!!!
Old 11-28-2003, 05:17 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
id contact Apex about that.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 11-29-2003, 03:59 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
You are building a LS/Vtec then, using a USDM 90 B18A1 block, correct? I am guessing you are in Japan. Which head are you using, a B16A head? Couldn't you use a AT B16A ecu. I know there where AT B16A's in Japan. The Civic Ferio SiR (or was it the SiR II) had an AT B16A. I would think that ecu should work to control the Vtec on an LS/Vtec if that's what you are trying to build. Also, I am not sure, but couldn't you get the obd-I ecu from a AT B16A and convert it to non-obd. It's 1am here, so if that last thought is wrong, sorry. I do know that AT B16A's did exist in Civic's in Japan, and that a fair chunk of the SiR or SiR-II Civic Ferio's came with an AT b16A. As for where the Apex'i unit can contol the vtec without a vtec ecu...you'd probably have to contact Apex'i. I do know a shop in Arizona that could probably answer your questions. They do lots of stuff, and know there LS/Vtec info very well. However, if you are indeed in Japan, I doubt you want to call Arizona. If I am wrong, let me know and I can give you the number and name. I hope I helped a bit. Sorry I couldn't help more, but it's 1am and I didn't get much sleep last night, so I am very tired.
Old 11-30-2003, 10:05 AM
Re: automatic LS/v-tec questions
no,no I live in tennessee, and I bought the JDM TEg XSi from a friend who imported it on e-bay and wreaked it and sold it to me for a grand, some mods, and a '99 civic Si obd 2 emissions system so it would pass inspections.....I bought the LS to start driving, because the XSi is so valuable to me, and it is starting to have issues with the electrical system.....
no, the Civic Ferio was a OBD-1 i beleive, and I dunno how to convert it w/o buying a harness with $$$ I don't have..... the PW0 would work and so would the PR3, but I have serched literally 1000's of pages looking for one, but no luck on a stock one, hondata does carry one though for 400+ tuning time, which is too much for me, $200 is about what I can spend on it.the cmoplete B16A is swaped and hooked up in the tranny the electronics just need work....
Old 12-01-2003, 02:51 AM
Honda God
Okay, you have me confused now. So you have a JDM Integra XSi and a USDM LS Integra? The JDM XSi has a B16A? So you kepted the B18A1 in the LS or put in a B16A? I got the impression you threw the B16A head onto the LS block since you said "LS/Vtec" in the title. But your 2 posts seem to confuse me as to what engine is going into or is in what. I am guessing it's either a B16A into your 90 LS or you are LS/Vtec'ing the B18A1 from the 90LS, since you need the Vtec ecu for the car. So this is going into the 90 LS you are refering to, not the XSi, correct? I know the Civic Ferrio AT B16A ecu would work, if you convert it, but you said you can't afford to mess with or buy a wiring harrness. Hmm, I don't know what to say, if you can't afford the Hondata either. Would you have to mess with tuning on it? I mean, couldn't you buy the hondata and just leave the tuning stock, it should run fine since you don't have a highly modded motor I am guessing. If O can ask, what year is the XSi? So it has a B16A in it you said? The XSi was the rare all-wheel drive JDM Integra that didn't sell too well, wasn't it?
Old 12-05-2003, 05:16 PM
okay, I am going to answer your questions backwards. The XSi was front wheel.. The ZXi was allwheel with a D16Y. I droped the whole B16A in there with a LS crank. the B16A I droped in was the original motor for the XSi, but I blew it and was going to use it as a parts motor but got the LS and decided to rebuild it and drop in in the LS...The hondata system comes with noting programed on the ECU and therefore you have to add specs just to even get your car to start...Hondata doesn't sell Auto tranny, pre-obd, vtec ECU'sThe apex unit V-AFC II might work though..
Old 12-06-2003, 11:52 PM
Honda God
Re: Re: automatic LS/v-tec questions
A Hondata doesn't even come with stock maps? Thats messed up. And you said you can't use the Civic Ferro AT B16A ecu, becuase you can't afford to convert it to non-OBD, correct? Let me know what you find out about the V-AFC II.
Superior Racing Development in Tempe, AZ might be able to help you out with your ecu problem. They are pretty knowledgable. I beleive it was Jeff Mattison I used to talk to on the phone there. If I remembered correct, he might be able to help you out.
toll free: 1-888-461-8805
local number: 480-317-0090
1980 East 5th Street #101
Tempe, Arizona 85281
http://www.superiorracing.com
LS to an LS/V-Tec str8_silver Integra 7 05-29-2004 09:24 PM
LS/v-tec help needed!! HondaIntegraXSI Integra 1 12-27-2003 10:16 PM
LS/v-tec help needed!! HondaIntegraXSI Engineering/ Technical 1 12-27-2003 10:15 PM
My LS v-tec and a snowy road HondaIntegraXSI Street Racing 8 12-10-2003 11:23 PM
ls-v-tec build up on a 92 b18a grncivicdhr Engineering/ Technical 5 05-16-2002 07:39 PM
