Go Back   Automotive Forums Car Chat > Honda > Integra
Old 05-27-2004, 01:25 AM
str8_silver str8_silver is offline
Cool LS to an LS/V-Tec
I have a 96 LS and i have been looking around for a V-Tec head. I guess im wondering if that is the best way to go about getting more beef under the hood. I also want to know where the best place is to get a new head from, and how much it will cost, and do i need to up grade any more of my engine when putting on a new head.
Old 05-27-2004, 02:09 AM
95TegSE's Avatar
95TegSE 95TegSE is offline
Check Ebay for heads, the best for the money is the pr3 from the b16. Also, check junkyards. You'll need to get an obd-2 vtec distributor. You'll also need an obd-2 vtec ecu, such as a p28 (chipped), or a p72 from the gsr. I've heard that you should also get pistons from a vtec engine because the non-vtec b-series pistons don't have big enough valve reliefs. Companies make vtec conversion kits with the oil lines and dual sized dowel pins now, so that's easier. Try Golden Eagle for their kit. It'll run you anywhere from $400-1000 for the head alone depending on what you get and how good its condition is. The Golden Eagle kit is around $250. An ecu might run you around $200, and the distributor, I'm not quite sure about because I've seen new ones for like $250, but I'm sure you can get one for way cheaper. LS/VTEC's not as cheap as some people think it is to do right. You won't see as much of a horsepower per dollar gain as you will for turbo. Turbo may be more expensive, but you'll see way better gains.
From the foothills to the bay, it shall ring, as we sing,
It shall ring and float away; Hail, Stanford hail! Hail, Stanford hail!
Old 05-27-2004, 11:08 AM
Crippy's Avatar
Crippy Crippy is offline
Re: LS to an LS/V-Tec
what do ya know ... its the weekly " should i go ls/vtec" question ...
Old 05-27-2004, 01:37 PM
Re: Re: LS to an LS/V-Tec
I didnt ask if i should go LS/V-Tec....I said Im going LS/V-Tec and I was Asking for information on how much it should cost and the best parts to buy.
Old 05-27-2004, 01:39 PM
Thanx a lot for the info 95.... ill make sure and check that out
Old 05-27-2004, 03:20 PM
Crippy's Avatar
[quote=str8_silver]I have a 96 LS and i have been looking around for a V-Tec head. I guess im wondering if that is the best way to go about getting more beef under the hood.
oh yea ... anyways you should try searching the forums for that , its talked about quite often ...
Old 05-27-2004, 11:10 PM
loesch8102's Avatar
loesch8102 loesch8102 is offline
Send a message via AIM to loesch8102
If everybody stopped asking questions like this, we wouldn't have anything to talk about anymore though.
Old 05-29-2004, 08:24 PM
shopcartrice shopcartrice is offline
yeah man does it really hurt you that much to see it listed as a question and if it does why read the thread AND respond to it just move on go race your car around
