Old 11-26-2003, 10:59 PM
eillob's Avatar
eillob eillob is offline
Nos
Ive got a nos question. How much retard in timming do you need for a 100hp shot of NOS? This particular car has an APE chip which naturally advances timming, should the chip stay? Or should it be dumped.
I talked to some gear heads the other day and one guy said if the shot is small enough you dont have to bother with retard in timming. I think I'll research that myself, but I want to know what everyone thinks.
Old 11-26-2003, 11:52 PM
Razor19 Razor19 is offline
Send a message via AIM to Razor19
If you have a mustang then dont put NOS or any other nitrous at all. If you have an import then I guess its ok I'm not a big fan of nitrous at all. It's just a temporary boost of horsepower. In my opinion save up for a super or a turbo that is horsepower that lasts.
"Only babies suck bottles"
Old 11-27-2003, 07:59 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Nos
Nitrous is cheap and easy, and I don't see a problem with it. Now I would set the timing back to stock, 10*, and ditch the chip! What mods are done to the car to necessitate a chip in the first place?
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 11-27-2003, 08:23 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
I don't know what year ya car is cause it changes a few things but general rule of thumb for a 100 shot one step colder plugs(learn how to read plugs) and 2 degress retard.
Get rid of that chip!!!!!!!
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 11-27-2003, 10:59 AM
rerun rerun is offline
well as long as you don't say it like "nawz" then its cool, i think 100shot shouldn't be a problem. get rid of the chip!!!!!
oh and, when your posting thinka bout calling it N20, gets less people steamed and is the proper name for it. NOS, is a company
Old 11-27-2003, 09:31 PM
eillob's Avatar
Re: Re: Nos
30lb injectors more air added via cobra intake and cold air with K&N,1.7 rollers with 190lgh fuel pump. The chip seems to make the car run cooler as well as increase horse power.
Old 11-28-2003, 03:39 AM
HiFlow5 0's Avatar
Stanger
Re: Re: Re: Nos
I bet you can get the same results by just advancing the timing manually, running a performance thermostat and tweaking the fuel pressure. In any case, I would lose the chip if you plan on running nitrous. Was the chip custom burned for your set up, or is it just a generic off the shelf one?
-2013 Ford Flex
-1999 Ford F150
Old 11-28-2003, 08:13 AM
eillob's Avatar
The chip came out of another mustang same year with same upgrades.
Old 11-28-2003, 09:06 AM
HiFlow5 0's Avatar
Stanger
Re: Nos
But was it custom burned, or is it generic? What brand?
-2013 Ford Flex
-1999 Ford F150
Old 11-28-2003, 09:16 AM
eillob's Avatar
Custom burned, By APE
Old 11-28-2003, 11:28 AM
GTStang's Avatar
Stang Guy
As far as chip goes you want a flip chip so that you have two settings one for N/A and one for NO2.
Old 12-04-2003, 08:35 PM
parrish5o's Avatar
parrish5o parrish5o is offline
Re: Nos
The rule of thumb I have gone by is 2degrees for every 50 hp. I use an MSD adjustable timing control for this. I always run 93 at least and if I plan on running the juice I add NOS octaing boost. I have very good luck with this system and it drops over a full second off my 1/4 time slip.
Old 12-04-2003, 09:36 PM
eillob's Avatar
Think I'll go the supercharger route. I dont think I like the idea of having to refill the bottle. How much boost is enough obviously I'm thinking MAX like 9psi. But I don't want to destroy the engine. How much of a horse power increase can I expect from 6psi?
Old 12-05-2003, 12:05 AM
hot_red_z28 hot_red_z28 is offline
Send a message via ICQ to hot_red_z28 Send a message via AIM to hot_red_z28
Re: Nos
The choice of nitrous also needs to consider what you want to use the car for. If you want the car to be a daily driver, with the occasional ass hauling race, then go with nitrous. If you like to rip it up at the track constantly, or you want a car that is always scratchin the tires, then go with a blower or turbo.
Things to consider though are that a blower cost about 4 to 5 times as much as nitrous. On the other hand, there is no bottle to fill on a blower or turbo...
My Project Write-Up
Old 12-07-2003, 01:17 PM
95gts98gt 95gts98gt is offline
Send a message via AIM to 95gts98gt
Re: Nos
if you have a 5.0, and your run a 100 shot of n2o adjust the timing to 12 degrees, there it is simple and easy.thats all you have to know..o by the way that chip is a waste of money! buy and MSD digital 5.
95 GTS...9mm FRPP spark plug wires, BONE STOCK
