Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 11-26-2003, 01:43 PM   #1
richlover27
1998 Lumina
if there is water in the oil,will that be the reason the engine taps when i start it up in the morning.once it get hot the tapping stops
richlover27 is offline   Reply With Quote
Old 11-26-2003, 01:47 PM   #2
maybe2fast
Re: 1998 Lumina
if it is the 3.1 these are good engines but they make alot of noise (ticking and cluking it is just the 3.1 and 3100 and 3400 noises) if there is coolant in the oil get that in the service garage fast or you will need more than head gaskets!
maybe2fast is offline   Reply With Quote
Old 11-26-2003, 01:49 PM   #3
maybe2fast
Re: 1998 Lumina
get that coolant out of the oil quick it is tearing the lower end of the engine up
Old 11-28-2003, 12:06 AM   #4
Retardo
Re: 1998 Lumina
The engine tapping is nothing more than valve noise. Most of the cars do it, but some do it so quietly, it's hard to hear it.
Get an old water hose and cut off about 2 feet of it. Put one end of it on the valve covers and the other end of it to your ear. You should be able to identify where the noise is coming from. If it's coming from under the valve covers, I wouldn't worry about it. Its normal!
As for the coolant, if there's water in the oil, but no steam in the exhaust, it's probably nothing more than a intake gasket. Fairly easy to change out, only if you have the right materials (torque wrenches, air tools, manuals, etc..)
Retardo is offline   Reply With Quote
1998 lumina ltz starting problems luminakid1992 Lumina 17 05-22-2011 11:55 PM
Noise in 1998 Lumina sallyasp Lumina 3 12-13-2003 12:07 AM
1998 lumina 3.1 richlover27 Lumina 1 11-30-2003 01:24 AM
1998 Lumina LTZ - 3800 engine 77_Vette Engineering/Technical 8 11-19-2003 09:36 PM
Removing Speed Govenor on my 1998 Lumina?? PLumina Lumina 2 10-30-2003 08:49 PM
