Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 11-26-2003, 12:24 PM
rcotten rcotten is offline
Clicking & shaking with service engine light
I have a 00 Pontiac Montana. When you start it up, the service engine light is flashing. The van is making a "clicking" noise and shaking. If you give it gas, with will not go very fast and the shaking gets much worse. Any thoughts? I have a warranty on it, but I had to waste the time and money of going to the dealer, if it isn't something that is covered by the warranty. Also, the service engine light is on and blinking.
Old 11-26-2003, 07:35 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Re: Clicking & shaking with service engine light
What name is your warranty? It sounds like you have a misfire, most extended warranty companies will cover the problem and the GM warranty will fix is free of charge!!
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 11-26-2003, 10:06 PM
I bought the used Pontiac at a Ron Tirapelli Ford dealer. The Warranty is called Basecare. They aren't very helpful there and always give me problems when I take the vehicle in. Hopefully this will be covered.
11-28, I took the van in this morning. Unfortunately they have to replace the coil and it isn't covered by the warranty ($250.00).
Old 11-28-2003, 11:19 PM
Boddingtons Boddingtons is offline
Do it yourself. The part is around $50, and the job is an easy DIY. Even if you replace all three coil packs (which many recommend when one goes bad) you'll still be ahead of the game...
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 03:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 06:16 PM
grand am engine light? confuoco1 Grand AM 1 04-01-2009 05:06 PM
need help with service engine light and srs mrcarauto S80 8 09-27-2005 10:58 PM
flashing "d" light, and then code 43 with service engine light mwenz33 Accord/TSX/Accord Hybrid 5 08-24-2004 01:52 PM
