Old 11-26-2003, 10:23 AM
4g4d_getone's Avatar
4g4d_getone 4g4d_getone is offline
ecu
like i said b 4 i got the jdm d15b vtec it comes with its own intake manifold and distributer but no ecu. the motor i got in my car now has the crx si intake manifold and distributer.
my question is if i put the crx si manifold and distributer on the d15b can i still use a 95 si ecu or will i have the get the 95 si manifold and distributer to match.
Y LOOK FAST WHEN YOUR NOT?????????
Old 11-26-2003, 11:07 AM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Re: ecu
You should be able to use your D15b intake manifold and distributor with the 92-95 si ecu (P28).
Check out my car here My 91 Hatch
Old 11-26-2003, 01:13 PM
i dont know the distributer cap is cracked and i dont know where to get another one. i want to either use the crx si parts or 95 si parts cause i want to use the 95 si ecu.
Old 11-26-2003, 09:39 PM
Re: ecu
Then use the 95 Si parts they will be the same as the others.
Old 11-27-2003, 01:28 AM
outofstep's Avatar
outofstep outofstep is offline
Send a message via AIM to outofstep
Re: ecu
do you have the motor running yet? what car did you put this in? im gonna be swapping in the same motor into my 90hb and id like to hear what you think of the swap. also what all you had to change.
90 civic:
JDM d15b
CAI
hp racing headers 4:2:1
custom 2 1/4 exhaust no cat
vafc2
skunk2 adj cam gear
B&M fpr
B&M fpg
tockico illumnia 5ways
eibach sportline
front & rear strut bars
CF SIR hood
Check out outofgames.net for your gaming needs!
Old 12-01-2003, 09:31 AM
im about to put it in like in a couple weeks im trying to get everything first
its going in a 88 civic dx 4dr
ecu ecu ecu i see you MODIFIED_GSR Integra 7 05-04-2005 09:31 PM
converting ecu plugs to OBD-1 ???? p08 ecu install SIvic '88 - '91 Civic | CRX | Wagon | Shuttlee 2 03-21-2003 12:28 PM
88 ls ecu vs 89 ls ecu outofstep '71-'87 Civic | CRX 5 04-13-2002 01:41 PM
99 G20 ECU vs 98 Primera ECU bafo Engine 2 01-29-2002 01:29 PM
